Changes between Version 32 and Version 33 of WKTRaster/SpecificationWorking02
Sep 21, 2010, 6:50:27 AM (14 years ago)
pracine
  • WKTRaster/SpecificationWorking02
    v32 v33
    1515}}}
    1616
     17----
     18== '''Objective 2.0.01 - Being able to get and set the rotation of a raster''' ==
     19
     20'''ST_SetRotation(raster, angle)'''
     21
     22 Set the rotation of the raster. This method actually derive values for pixelsizex, pixelsizey, skewx and skewy based on the provided rotation angle.
     23
     24 '''Open Question:'''
     25  PR: The angle should be provided in radian or in degree?
     27'''ST_Rotation(raster) -> float64'''
     28 Return the georeference's rotation angle in (degree or radiant?) derived from the pixel size and the skew.
     29
     30  PR: I think getting the rotation get no sence since the result of pixelsizes and skew is not necessarily a rotation. It make sence to set it though.
     31
     32----
     33== '''Objective 2.0.02 - Being able to create a raster as the expression of another raster''' ==
     34
     35
     36
    1737----
    1838== '''Objective 2.0.04 - Implement better support for NULL, Empty, !HasNoBand(rast), !HasNoBand(rast, band) and !BandIsNoData rasters in all functions.''' ==
    98118 This function is necessary to optimize ST_Intersection. The raster to be polygonised before proceeding to a vector intersection should first be clipped to the minimal intersecting area using ST_Clip().
    99119
    100
    101 ----
    102 == '''Objective 2.0.01 - Being able to get and set the rotation of a raster''' ==
    103
    104 '''ST_SetRotation(raster, angle)'''
    105
    106  Set the rotation of the raster. This method actually derive values for pixelsizex, pixelsizey, skewx and skewy based on the provided rotation angle.
    107
    108  '''Open Question:'''
    109   PR: The angle should be provided in radian or in degree?
    110
    111 '''ST_Rotation(raster) -> float64'''
    112  Return the georeference's rotation angle in (degree or radiant?) derived from the pixel size and the skew.
    113
    114   PR: I think getting the rotation get no sence since the result of pixelsizes and skew is not necessarily a rotation. It make sence to set it though.
    115
