Changes between Initial Version and Version 1 of WKTRaster/RFC/RFC1_V0SerialFormat
01/25/15 10:37:43 (10 years ago)
dustymugs
  • TabularUnified WKTRaster/RFC/RFC1_V0SerialFormat
     1= RFC1: serialized format (storage) for RASTER type =
     3'''Author''': Sandro Santilli <strk@keybit.net>[[BR]]
     4'''Date''': 2009-01-28[[BR]]
     5'''Status''': Adopted
     7 Revisions::
     8   2011-01-24 by Jorge Arévalo
     9   - Adds isNodataValue bit to band flags
     10
     11== Goals ==
     12
     13The goals of the serialized version for RASTER type are:
     14
     15 - Small memory footprint on deserialization
     16   This means that the amount of allocated memory
     17   required for deserialization is minimal
     18
     19 - Fast access
     20   Access to band data must be aligned, saving from
     21   memory copies on full scan.
     23 - Ease of format switch
     24   On-disk format must be allowed to change
     25   w/out need for dump-reload of the whole
     26   database.
     27
     28The first two goals boil down to forcing alignment of band
     29data in the serialized format itself, which in turn will
     30require variable padding based on pixeltype of each band.
     31
     32For simplicity we will ensure that each band of the
     33raster starts at the 8-byte boundary and thus pad
     34previous structures in the stream accordingly.
     35
     36The structure will then look like this:
     37
     38{{{
     39[HEADER]  [BAND0]    [BAND1]    [BAND2]
     40          ^aligned   ^aligned   ^aligned
     41}}}
     42
     43The third goal can be accomplished by adding a version
     44number to the serialized format so that in case of changes
     45the deserializer can pick the correct parsing procedure
     46based on that.
     47
     48== The HEADER ==
     49
     50PostgreSQL forces a 4-byte size field a the start of
     51the detoasted datum, and ensure this start of structure
     52is aligned to 8-byte.  We'll add version number right after it,
     53and then make sure the total size is a multiple of 8 bytes.
     54
     55The following structure is composed by 8 slots of 8-bytes,
     56totaling 64 bytes:
     57
     58{{{
     59struct rt_raster_serialized_t {
     60
     61    /*---[ 8 byte boundary ]---{ */
     62    uint32_t size;    /* required by postgresql: 4 bytes */
     63    uint16_t version; /* format version (this is version 0): 2 bytes */
     64    uint16_t numBands; /* Number of bands: 2 bytes */
     65
     66    /* }---[ 8 byte boundary ]---{ */
     67    double scaleX; /* pixel width: 8 bytes */
     68
     69    /* }---[ 8 byte boundary ]---{ */
     70    double scaleY; /* pixel height: 8 bytes */
     71
     72    /* }---[ 8 byte boundary ]---{ */
     73    double ipX; /* insertion point X: 8 bytes */
     74
     75    /* }---[ 8 byte boundary ]---{ */
     76    double ipY; /* insertion point Y: 8 bytes */
     78    /* }---[ 8 byte boundary ]---{ */
     79    double skewX;  /* rotation about the X axis: 8 bytes */
     80
     81    /* }---[ 8 byte boundary ]---{ */
     82    double skewY;  /* rotation about the Y axis: 8 bytes */
     83
     84    /* }---[ 8 byte boundary ]--- */
     85    int32_t srid; /* Spatial reference id: 4 bytes */
     86    uint16_t width;  /* pixel columns: 2 bytes */
     87    uint16_t height; /* pixel rows: 2 bytes */
     88};
     89}}}
     90
     91== The BANDS ==
     92
     93Given the serialized raster header structure above, it
     94is guaranteed that a serialized band always start at 8-bytes
     95boundary, so it's simpler to compute padding required at
     96the end of each band to ensure next band will be guaranteed
     97the same assumption.
     98
     99We'll need to take 2 padding spots into account:
     100the first is to ensure actual band data is aligned accordingly
     101to the pixel type (and storage flag) needs, the second is to
     102ensure next band (if any) will also be aligned to 8-bytes:
     103
     104{{{
     105[PIXELTYPE+STORAGE_FLAG] [DATA_PADDING] [DATA] [TRAILING_PADDING]
     106}}}
     107
     108The total size of a band's serialized form in bytes
     109must be a multiple of 8.
     110
     111The maximum required data padding size will be of 7 bytes
     112(64bit pixel type). The maximum required trailing padding size
     113will be of 7 bytes.
     114
     115=== Pixel type and storage flag ===
     116
     117Pixel type specifies type of pixel values in a band.
     118Storage flag specifies whether the band data is stored
     119as part of the datum or is to be found on the server's
     120filesytem.
     121
     122There are currently 11 supported pixel value types, so 4
     123bits are enough to account for all. We'll reserve
     124the upper 4 bits for generic flags and define upmost as
     125storage flag:
     126
     127{{{
     128#define BANDTYPE_FLAGS_MASK 0xF0
     129#define BANDTYPE_PIXTYPE_MASK 0x0F
     130
     131#define BANDTYPE_FLAG_OFFDB     (1<<7)
     132#define BANDTYPE_FLAG_HASNODATA (1<<6)
     133#define BANDTYPE_FLAG_ISNODATA  (1<<5)
     134#define BANDTYPE_FLAG_RESERVED3 (1<<4)
     135}}}
     136
     137=== Data padding ===
     138
     139Band alignment depends on pixeltypes, as follows:
     140
     141 * '''PT_1BB''', '''PT_2BUI''', '''PT_4BUI''', '''PT_8BSI''', '''PT_8BUI''': No alignment required, each value is 1 byte.
     142
     143 * '''PT_16BSI''', '''PT_16BUI''': Data must be aligned to 2-bytes boundary.
     144
     145 * '''PT_32BSI''', '''PT_32BUI''', '''PT_32BF''': Data must be aligned to 4-bytes boundary.
     146
     147 * '''PT_64BF''': Data must be aligned to 8-bytes boundary.
     148
     149Accordingly we can then define the following structures:
     150
     151{{{
     152struct rt_band8_serialized_t {
     153    uint8_t pixeltype;
     154    uint8_t data[1]; /* no data padding */
     155}
     156
     157struct rt_band16_serialized_t {
     158    uint8_t pixeltype;
     159    uint8_t padding; /* 1-byte padding */
     160    uint8_t data[1];
     161}
     162
     163struct rt_band32_serialized_t {
     164    uint8_t pixeltype;
     165    uint8_t padding[3]; /* 3-bytes padding */
     166    uint8_t data[1];
     167}
     168
     169struct rt_band64_serialized_t {
     170    uint8_t pixeltype;
     171    uint8_t padding[7]; /* 7-bytes padding */
     172    uint8_t data[1];
     173}
     174}}}
     175
     176And an abstract base class:
     177
     178{{{
     179struct rt_band_serialized_t {
     180    uint8_t pixeltype
     181}
     182}}}
     183
     184=== Data ===
     185
     186The band data - guaranteed to be always aligned as required by
     187pixeltype - will start with the nodata value.
     188
     189After that we may have pixel values or off-db raster reference depending on OFFDB flag in the pixeltype field:
     190
     191 * For in-db bands the nodata value is followed by a value for each column in first row, then in second row and so on. For example, a 2x2 raster band data will have this form:
     192{{{
     193[nodata] [x:0,y:0] [x:1,y:0] [x:0,y:1] [x:1,y:1]
     194}}}
     195 Where the size of the [...] blocks is 1,2,4 or 8 bytes depending on pixeltype. Endiannes of multi-bytes value is the host endiannes.
     196
     197 * For off-db bands the nodata value is followed by a band number followed by a null-terminated string expressing the path to the raster file:
     198{{{
     199[nodata] [bandno] [path]
     200}}}
     201 Where the size of the [nodata] block is 1,2,4 or 8 bytes depending on pixeltype (endiannes of multi-bytes value is the host endiannes), size of [bandno] is 1 byte, and [path] is null-terminated.
     202
     203=== Trailing padding ===
     204
     205The trailing band padding is used to ensure next band (if any) will start on the 8-bytes boundary. It is both dependent on raster dimensions (number of values) and band data pixel type (size of each value).
     206
     207In order to obtain the required padding size for a band we'll need to compute the minimum size required to hold the band data, add the data padding and pixeltype sizes, and then grow the resulting size to reach a multiple of 8 bytes:
     208
     209{{{
     210size_t
     211rt_band_serialized_size(rt_context ctx, rt_band band)
     212{
     213    rt_pixtype pixtype = rt_band_get_pixtype(ctx, band);
     214    size_t sz;
     215
     216    /* pixeltype + data padding */
     217    sz = rt_pixtype_alignment(ctx, pixtype);
     218
     219    /* add data size */
     220    sz += rt_band_get_data_size(ctx, band);
     221
     222    /* grow size to reach a multiple of 8 bytes */
     223    sz = TYPEALIGN(sz, 8);
     224
     225    assert( !(sz%8) );
     226
     227    return sz;
     228}
     229}}}
     230
     231== Example sizes ==
     232
     233{{{
     234255x255 single band PT_16BUI:
     235    header size:                        64 +
     236    pixeltype+data_padding:              2 +
     237    data size:     (255*255+1)*2 == 130052 =
     238                                    130118 +
     239    trailing padding:                    2 =
     240    total size:                     130120 (~127k)
     241}}}
     242{{{
     243255x255 single band PT_8BUI:
     244    header size:                        64 +
     245    pixeltype+data_padding:              1 +
     246    data size:        (255*255+1) == 65026 =
     247                                     65091 +
     248    trailing padding:                    5 =
     249    total size:                      65096 (~63k)
     250}}}
     251{{{
     25264x64 single band PT_16BSI:
     253    header size:                        64 +
     254    pixeltype+data_padding:              2 +
     255    data size:         (64*64+1)*2 == 8194 =
     256                                      8260 +
     257    trailing padding:                    4 =
     258    total size:                       8264 (~8k -- >page size)
     259}}}
     260{{{
     26164x64 single band PT_8BUI:
     262    header size:                        64 +
     263    pixeltype+data_padding:              1 +
     264    data size:           (64*64+1) == 4097 =
     265                                      4162 +
     266    trailing padding:                    6 =
     267    total size:                       4168 (~4k)
     268}}}
