Changes between Version 53 and Version 54 of WKTRaster/PlanningAndFunding
- Apr 16, 2009, 9:08:09 AM (15 years ago)
v53 v54 100 100 ||'''Objectives and Tasks'''||'''Coder'''||'''Approx. Schedule'''||'''Time'''||'''Fund (US$)'''||'''Status'''|| 101 101 102 ||[[BR]]''' B03a - Being able to set all the properties of a raster.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||102 ||[[BR]]'''Objective B03a - Being able to set all the properties of a raster.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])|| 103 103 ||- RT_SetSRID(raster|geometry, integer)[[BR]]- RT_SetPixelType(raster, band, string)[[BR]]- RT_SetPixelSize(raster)[[BR]]- RT_SetNoDataValue(raster, band, value)[[BR]]- RT_SetGeoReference(raster, string)||TBD||||1 week||1200||todo|| 104 ||[[BR]]''' B03b - Being able to reproject a raster.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||104 ||[[BR]]'''Objective B03b - Being able to reproject a raster.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])|| 105 105 ||- RT_Transform(raster|geometry, SRID) -> same type as input||TBD||||1 week||1200||todo|| 106 ||[[BR]]''' B03c - Being able todo some base raster operations.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||106 ||[[BR]]'''Objective B03c - Being able todo some base raster operations.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])|| 107 107 ||- RT_Area(raster|geometry) -> double[[BR]]- RT_Count(raster, value) -> integer[[BR]]- RT_Resample(raster, pixelsize, method) -> raster[[BR]]- RT_SelectByValue(raster|geometry, ‘expression’) -> same type as first argument[[BR]]- RT_Reclass(raster|geometry,string) -> same type as first argument[[BR]]- RT_MapAlgebra(raster|geometry, [raster|geometry,...], ‘mathematical expression’, ‘raster’ |’geometry’) -> raster/geometry[[BR]]- RT_Clip(raster|geometry,geometry) -> same type as first argument[[BR]]- RT_Flip(raster|geometry, ’vertical’|’horizontal’) -> same type as first argument||TBD||||6 weeks||7200||todo|| 108 ||[[BR]]''' B04a - Being able to convert a raster to standards formats.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||108 ||[[BR]]'''Objective B04a - Being able to convert a raster to standards formats.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])|| 109 109 ||- RT_AsKML(raster|geometry) -> string[[BR]]- RT_AsSVG(raster|geometry) -> string||TBD||||2 weeks||2400||todo|| 110 ||[[BR]]''' B04b - Being able to control the validity of a raster.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||110 ||[[BR]]'''Objective B04b - Being able to control the validity of a raster.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])|| 111 111 ||- RT_IsEmpty(raster|geometry) -> boolean[[BR]]- RT_mem_size(raster|geometry) -> integer[[BR]]- RT_isvalid(raster|geometry) -> boolean||TBD||||1 week||1200||todo|| 112 ||[[BR]]''' B04c - Being able to use other major topological operators.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||112 ||[[BR]]'''Objective B04c - Being able to use other major topological operators.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])|| 113 113 ||- RT_Within(raster|geometry A, raster|geometry B)[[BR]]- RT_Contains(raster|geometry A, raster|geometry B)[[BR]]- RT_Overlaps(raster|geometry, raster|geometry)||TBD||||1 week||1200||todo|| 114 ||[[BR]]''' B05a - Being able to derive a raster layer from vector layer.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||114 ||[[BR]]'''Objective B05a - Being able to derive a raster layer from vector layer.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])|| 115 115 ||- RT_Interpolate(points, pixelsize, method) -> raster||TBD||||1 week||1200||todo|| 116 ||[[BR]]''' B05b - Being able todo on rasters most operations available on geometries.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||116 ||[[BR]]'''Objective B05b - Being able todo on rasters most operations available on geometries.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])|| 117 117 ||- RT_Centroid(raster|geometry) -> point geometry[[BR]]- RT_PointOnSurface(raster|geometry) -> point geometry[[BR]]- RT_Buffer(raster|geometry, double) -> same type as first arg.[[BR]]- RT_ConvexHull(raster|geometry) -> same type as input[[BR]]- RT_Difference(raster|geometry A, raster|geometry B) -> same type as first argument[[BR]]- RT_SymDifference(raster|geometry,raster|geometry,‘raster’|’geometry’) -> raster/geometry||TBD||||4 weeks||4800||todo|| 118 ||[[BR]]''' B06a - Being able to use all the other topological operators.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||118 ||[[BR]]'''Objective B06a - Being able to use all the other topological operators.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])|| 119 119 ||- RT_Equals(raster|geometry, raster|geometry)[[BR]]- RT_Disjoint(raster|geometry, raster|geometry)[[BR]]- RT_Touches(raster|geometry, raster|geometry)[[BR]]- RT_Crosses(raster|geometry, raster|geometry)[[BR]]- RT_Covers(raster|geometry A, raster|geometry B)[[BR]]- RT_IsCoveredBy(raster|geometry A, raster|geometry B)[[BR]]- RT_Relate(raster|geometry, raster|geometry, intersectionPatternMatrix )||TBD||||2 weeks||2400||todo|| 120 ||[[BR]]''' B07b - Being able to edit a raster.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||120 ||[[BR]]'''Objective B07b - Being able to edit a raster.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])|| 121 121 ||- RT_SetValue(raster, band, x, y, value)[[BR]]- RT_Affine(raster|geometry,...) -> same type as input[[BR]]- RT_Translate(raster|geometry,...) -> same type as input[[BR]]- RT_Scale(raster|geometry,...) -> same type as input[[BR]]- RT_TransScale(raster|geometry,...) -> same type as input[[BR]]- RT_RotateZ,Y,Z(raster|geometry, float8) -> same type as input||TBD||||2 weeks||2400||todo|| 122 122 ||Other functions[[BR]]- RT_AsBinary(raster, compression)[[BR]]- RT_RasterFromWKB(raster, [<srid>])[[BR]]- RT_RasterFromText(string, [<srid>])[[BR]]- RT_AsText(raster)||TBD||||2 weeks||2400||todo||
