Changes between Version 129 and Version 130 of WKTRaster/PlanningAndFunding
Jun 13, 2011, 4:15:06 PM (13 years ago)
pracine
  • WKTRaster/PlanningAndFunding
    v129 v130
    102102||'''Objectives and Tasks'''||'''Coder'''||'''Approx. Schedule'''||'''Time'''||'''Approx. Contribution (US$)'''||'''Status'''||
    103103||[[BR]]'''Objective FV.01 - Being able to return a JPEG, a TIFF or a PNG ''- Done''''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||||||||||
    104 ||- ST_Band(raster, band) -> raster[[BR]]- ST_Reclass(raster|geometry,string) -> same type as first argument[[BR]]- ST_AsJPEG(raster, band, quality) -> JPEG as "bytea"[[BR]]- ST_AsTIFF(raster, band, compression) -> TIFF as "bytea"[[BR]]- ST_AsPNG(raster, band) -> PNG as "bytea"||ML||TBD||2 weeks||2400 / !DevTime from ML||todo||
     104||- ST_Band(raster, band) -> raster[[BR]]- ST_Reclass(raster|geometry,string) -> same type as first argument[[BR]]- ST_AsJPEG(raster, band, quality) -> JPEG as "bytea"[[BR]]- ST_AsTIFF(raster, band, compression) -> TIFF as "bytea"[[BR]]- ST_AsPNG(raster, band) -> PNG as "bytea"||BP||TBD||2 weeks||2400 / !DevTime from ML||todo||
    105105||[[BR]]'''Objective FV.02 - Being able to intersect vector and raster to produce raster.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||||||||||
    106106||- ST_AsRaster(geometry, pixelsize) -> raster[[BR]]- Changes to ST_Intersection||TBD||TBD||4 weeks||4800||todo||
    110110||- ST_Union(raster|geometry, raster|geometry, ‘raster’|’geometry’) -> raster/geometry[[BR]]- ST_Accum(raster set|geometry set, ‘raster’|’geometry’) -> raster/geometry||TBD||TBD||2 weeks||2400||todo||
    111111||[[BR]]'''Objective FV.05 - Being able to reproject a raster'' - Done''''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||||||||||
    112 ||- ST_Transform(raster|geometry, SRID) -> same type as input||TBD||||1 week||1200||todo||
     112||- ST_Transform(raster|geometry, SRID) -> same type as input||BP||||1 week||1200||todo||
    113113||[[BR]]'''Objective FV.06 - Being able todo some base raster operations.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||||||||||
    114 ||- ST_Area(raster|geometry) -> double[[BR]]- ST_ValueCount(raster, value) -> integer[[BR]]- ST_ValuePercent(raster, value) -> double precision[[BR]]- ST_Resample(raster, pixelsize, method) -> raster[[BR]]- ST_SelectByValue(raster|geometry, ‘expression’) -> same type as first argument[[BR]]- ST_Clip(raster|geometry,geometry) -> same type as first argument[[BR]]- ST_Flip(raster|geometry, ’vertical’|’horizontal’) -> same type as first argument||TBD||||6 weeks||7200||todo||
     114||- ST_Area(raster|geometry) -> double[[BR]]- ST_ValueCount(raster, value) -> integer'' - done''[[BR]]- ST_ValuePercent(raster, value) -> double precision'' - done''[[BR]]- ST_Resample(raster, pixelsize, method) -> raster[[BR]]- ST_SelectByValue(raster|geometry, ‘expression’) -> same type as first argument[[BR]]- ST_Clip(raster|geometry,geometry) -> same type as first argument[[BR]]- ST_Flip(raster|geometry, ’vertical’|’horizontal’) -> same type as first argument||TBD||||6 weeks||7200||todo||
    115115||[[BR]]'''Objective FV.07 - Being able to convert a raster to standards formats.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||||||||||
    116116||- ST_AsKML(raster|geometry) -> string[[BR]]- ST_AsSVG(raster|geometry) -> string||TBD||||2 weeks||2400||todo||
    127127||[[BR]]'''Objective FV.13 - Being able to edit a raster.''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||||||||||
    128128||- ST_Affine(raster|geometry,...) -> same type as input[[BR]]- ST_Translate(raster|geometry,...) -> same type as input[[BR]]- ST_Scale(raster|geometry,...) -> same type as input[[BR]]- ST_TransScale(raster|geometry,...) -> same type as input[[BR]]- ST_RotateZ,Y,Z(raster|geometry, float8) -> same type as input||TBD||||2 weeks||2400||todo||
    129 ||[[BR]]'''Objective FV.16 - Being able to quickly get raster statistics'' - Done''''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||||||||||
    130 ||- ST_SummaryStats(raster, nband) -> record[[BR]]- ST_ApproxSummaryStats(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision) -> record[[BR]]- ST_Count(raster, nband) -> bigint[[BR]]- ST_ApproxCount(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision) -> bigint[[BR]]- ST_Histogram(raster, nband) -> set of records[[BR]]- ST_ApproxHistogram(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision, bins int, width double precision[], right boolean) -> set of record[[BR]]- ST_Quantile(raster, nband) -> set of records[[BR]]- ST_ApproxQuantile(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision, quantiles double precision[]) -> set of records||TBD||||2 weeks||2400||todo||
     129||[[BR]]'''Objective FV.16 - Being able to quickly get raster statistics'' - done''''' ([wiki:WKTRaster/SpecificationWorking03 specifications])||||||||||
     130||- ST_SummaryStats(raster, nband) -> record[[BR]]- ST_ApproxSummaryStats(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision) -> record[[BR]]- ST_Count(raster, nband) -> bigint[[BR]]- ST_ApproxCount(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision) -> bigint[[BR]]- ST_Histogram(raster, nband) -> set of records[[BR]]- ST_ApproxHistogram(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision, bins int, width double precision[], right boolean) -> set of record[[BR]]- ST_Quantile(raster, nband) -> set of records[[BR]]- ST_ApproxQuantile(rast raster, nband int, exclude_nodata_value boolean, sample_percent double precision, quantiles double precision[]) -> set of records||BP||||2 weeks||2400||todo||
    131131||[[BR]]'''Other functions''' ||||||||||
    132132||- ST_AsBinary(raster, compression) ([wiki:WKTRaster/SpecificationWorking03 specifications])|| ML (start ST_AsBinary) || ||2 weeks||2400 / !DevTime from MD||in-progress||
