Changes between Version 95 and Version 96 of UsersWikiWinCompile
- Dec 1, 2009, 3:03:23 PM (15 years ago)
UsersWikiWinCompile
v95 v96 41 41 == 4. Installing GNUWin Support Packages == 42 42 43 Download and install the following from gnuwin32.sourceforge.net/packages.html43 Download and install the following from http://gnuwin32.sourceforge.net/packages.html. Run each file and be sure to change the install directory to '''c:\MinGW''' 44 44 45 45 * Bison, http://kent.dl.sourceforge.net/sourceforge/gnuwin32/bison-2.1.exe … … 47 47 * Flex, http://kent.dl.sourceforge.net/sourceforge/gnuwin32/flex-2.5.4a-1.exe 48 48 * !GetText, http://kent.dl.sourceforge.net/sourceforge/gnuwin32/gettext-0.14.4.exe 49 * Also get the !GetText dependencies file http://kent.dl.sourceforge.net/sourceforge/gnuwin32/gettext-0.14.4-dep.zip and unzip it into C:\MinGW 49 50 * Unzip, http://kent.dl.sourceforge.net/sourceforge/gnuwin32/unzip-5.51-1.exe 50 51 51 Run each file and be sure to change the install directory to c:\MinGW 52 52 53 53 54 == 5. Update m4 ==
