Changes between Version 225 and Version 226 of UsersWikiPostgreSQLPostGIS
07/09/24 06:11:59 (7 months ago)
robe
  • UsersWikiPostgreSQLPostGIS
    v225 v226
    33As of 21st Nov, 2023 these versions are latest and give you best stable feature coverage.
    44
    5  * PostGIS 3.4.1 [[Image(https://repology.org/badge/latest-versions/postgis.svg)]] https://postgis.net/2023/11/PostGIS-Patch-Releases/
     5 * PostGIS 3.4.2 [[Image(https://repology.org/badge/latest-versions/postgis.svg)]] https://postgis.net/2024/02/PostGIS-Patch-Releases/
    66 * PostgreSQL 16.1 [[Image(https://repology.org/badge/latest-versions/postgresql.svg)]] https://www.postgresql.org/docs/16/release-16.html
    7  * GEOS 3.12.1 [[Image(https://repology.org/badge/latest-versions/geos.svg)]] https://libgeos.org/usage/download/
    8  * SFCGAL 1.5.0 [[Image(https://repology.org/badge/latest-versions/sfcgal.svg)]] https://gitlab.com/sfcgal/SFCGAL/-/releases
    9  * GDAL 3.8.0 [[Image(https://repology.org/badge/latest-versions/gdal.svg)]] https://gdal.org/download.html#current-release
    10  * PROJ 9.3.0 [[Image(https://repology.org/badge/latest-versions/proj.svg)]] https://proj.org/en/9.3/download.html
    11  * protobuf-c 1.4.1 [[Image(https://repology.org/badge/latest-versions/protobuf-c.svg)]] https://github.com/protobuf-c/protobuf-c/releases
    12  * json-c 0.17 [[Image(https://repology.org/badge/latest-versions/json-c.svg)]] https://github.com/json-c/json-c
     7 * GEOS 3.12.2 [[Image(https://repology.org/badge/latest-versions/geos.svg)]] https://libgeos.org/usage/download/
     8 * SFCGAL 1.5.1 [[Image(https://repology.org/badge/latest-versions/sfcgal.svg)]] https://gitlab.com/sfcgal/SFCGAL/-/releases
     9 * GDAL 3.9.1 [[Image(https://repology.org/badge/latest-versions/gdal.svg)]] https://gdal.org/download.html#current-release
     10 * PROJ 9.4.1 [[Image(https://repology.org/badge/latest-versions/proj.svg)]] https://proj.org/en/9.4/download.html
     11 * protobuf-c 1.5.0 [[Image(https://repology.org/badge/latest-versions/protobuf-c.svg)]] https://github.com/protobuf-c/protobuf-c/releases
     12 * json-c 0.17 [[Image(https://repology.org/badge/latest-versions/json-c.svg)]] https://github.com/json-c/json-c/releases
    1313
    1414Obsolete versions can be found at - [[PostGISObsoleteVersionsMatrix]][[br]]
