Changes between Version 196 and Version 197 of UsersWikiPostgreSQLPostGIS
02/12/22 21:03:41 (3 years ago)
robe
  • UsersWikiPostgreSQLPostGIS
    v196 v197
    5959The none means that you can get that version to work without GEOS, though its not recommended since a lot of functions will not be installed.
    6060
    61 For the not recommended, this means that while you can get PostGIS to work with those versions, you'll be missing out on some PostGIS functions.
     61For the not recommended, this means that while you can get PostGIS to work with those versions, you'll be missing out on some PostGIS functions.
     62Yes (1) means we assume it works, but don't test it and haven't patched tests to regress cleanly.  Some regression tests may fail as newer version give slightly different answers from previous versions.
     63
     64Yes * - currently works but may not work at release time.
     65Blank slots means it doesn't work.
    6266
    6367
    64 ||'''Geos Version'''||'''PostGIS 1.3 EOL'''||'''PostGIS 1.4 EOL'''||'''PostGIS 1.5 EOL'''||'''PostGIS 2.0 EOL'''||'''PostGIS 2.1 EOL'''||'''PostGIS 2.2 EOL'''||'''PostGIS 2.3'''||'''PostGIS 2.4'''||'''PostGIS 2.5'''||'''PostGIS 3.0'''||'''PostGIS 3.1'''||'''PostGIS 3.2'''
    65 ||'''3.10'''||No||No||No||No||No||No||No||No||No||Yes*||Yes||Yes
    66 ||'''3.9'''||No||No||No||No||No||No||No||No||No||Yes||Yes||Yes
    67 ||'''3.8'''||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes
    68 ||'''3.7'''||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes
    69 ||'''3.6'''||Yes||Yes||Yes||Yes||Yes||Yes||Yes (recommended)||Yes*||Yes*
    70 ||'''3.5'''||Yes||Yes||Yes||Yes||Yes||Yes (recommended)||Yes*||Yes*||Yes*
    71 ||'''3.4'''||Yes||Yes||Yes (preferred 3.4.2+)||Yes (3.4.2+)||Yes||Yes*||Yes*||Yes*||No
     68||'''Geos Version'''||'''PostGIS 1.3 EOL'''||'''PostGIS 1.4 EOL'''||'''PostGIS 1.5 EOL'''||'''PostGIS 2.0 EOL'''||'''PostGIS 2.1 EOL'''||'''PostGIS 2.2 EOL'''||'''PostGIS 2.3'''||'''PostGIS 2.4'''||'''PostGIS 2.5'''||'''PostGIS 3.0'''||'''PostGIS 3.1'''||'''PostGIS 3.2'''||'''PostGIS 3.3'''
     69||'''3.11'''||No||No||No||No||No||No||No||No||No||No||Yes||Yes*||Yes
     70||'''3.10'''||No||No||No||No||No||No||No||No||No||Yes||Yes||Yes||Yes
     71||'''3.9'''||No||No||No||No||No||No||Yes (1)||Yes (1)||Yes (1)||Yes||Yes||Yes||Yes
     72||'''3.8'''||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes
     73||'''3.7'''||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes
     74||'''3.6'''||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes||Yes*
     75||'''3.5'''||Yes||Yes||Yes||Yes||Yes||Yes (recommended)||Yes||Yes||Yes||No||No
     76||'''3.4'''||Yes||Yes||Yes (preferred 3.4.2+)||Yes (3.4.2+)||Yes||Yes*||Yes*||Yes*
    7277||'''3.3 EOL'''||Yes||Yes||Yes (preferred 3.3.3+)||Yes (3.3.9+)||Yes (not recommended)||Yes*||[[span(style=color: grey, No)]]||[[span(style=color: grey, No)]]||No
    7378||'''3.2 EOL'''||Yes||Yes||Yes||Yes (not recommended)||[[span(style=color: grey, No)]]||[[span(style=color: grey, No)]]||[[span(style=color: grey, No)]]||[[span(style=color: grey, No)]]||No
