Changes between Version 125 and Version 126 of UsersWikiPostgreSQLPostGIS
03/27/18 12:20:48 (7 years ago)
robe
  • UsersWikiPostgreSQLPostGIS
    v125 v126
    6262GEOS 3.6.0 came out after 2.3.0 release, so most 2.3 distros will not have enabled - [http://postgis.net/docs/manual-2.3/ST_MinimumClearance.html ST_MinimumClearance*]  that require 3.6, but may in 2.3.1
    6363
    64 ||'''Geos Version'''||'''PostGIS 1.3'''||'''PostGIS 1.4'''||'''PostGIS 1.5'''||'''PostGIS 2.0'''||'''PostGIS 2.1'''||'''PostGIS 2.2'''||'''PostGIS 2.3'''||'''PostGIS 2.4 (Trunk)'''
    65 ||'''None'''||Yes (not recommended)||No||No|| No|| No|| No|| No
    66 ||'''2.2'''||Yes (not recommended)||No||No|| No|| No|| No|| No|| No
    67 ||'''3.0'''||Yes||Yes (not recommended)||No|| No|| No|| No|| No|| No
    68 ||'''3.1'''||Yes||Yes||Yes (not recommended) (requires 3.1.1+)|| No|| No|| No|| No|| No
    69 ||'''3.2'''||Yes||Yes||Yes||Yes (not recommended)|| No|| No|| No|| No
    70 ||'''3.3'''||Yes||Yes||Yes (preferred 3.3.3+)||Yes (3.3.9+)|| Yes (not recommended)|| Yes*|| No || No
    71 ||'''3.4'''||Yes||Yes||Yes (preferred 3.4.2+)||Yes (3.4.2+)|| Yes|| Yes*|| Yes* || Yes*
    72 ||'''3.5'''||Yes||Yes||Yes ||Yes|| Yes|| Yes (recommended) || Yes* || Yes*
    73 ||'''3.6'''||Yes||Yes||Yes ||Yes|| Yes|| Yes || Yes (recommended) || Yes
    74 ||'''3.7*'''||Yes||Yes||Yes ||Yes|| Yes|| Yes || Yes || Yes
     64'''Versions of PostgreSQL supported by which versions of PostGIS'''
     65||'''PostgreSQL Version'''||'''PostGIS 1.3 EOL'''||'''PostGIS 1.4 EOL'''||'''PostGIS 1.5 EOL'''||'''PostGIS 2.0 EOL'''||'''PostGIS 2.1 EOL''' ||'''PostGIS 2.2''' ||'''PostGIS 2.3'''||'''PostGIS 2.4'''||'''PostGIS 2.5 (Trunk)'''
     66||'''7.2-7.4'''||Yes (not windows)||No||No||No||No||No||No||No||No
     67||'''8.0'''||Yes (not windows)||No||No||No||No||No||No||No||No
     68||'''8.1'''||Yes||No||No||No||No||No||No||No||No
     69||'''8.2'''||Yes||Yes||No||No||No||No||No||No||No
     70||'''8.3'''||Yes||Yes||Yes||No||No||No||No||No||No
     71||'''8.4'''||Yes||Yes||Yes||Yes (not recommended)||No||No||No||No||No
     72||'''9.0'''||No||No||Yes||Yes (not recommended)||Yes (not recommended)||No||No||No||No
     73||'''9.1'''||No||No||Yes||Yes||Yes||Yes||No||No||No
     74||'''9.2'''||No||No||Yes* (1.5.6+)||Yes||Yes||Yes||Yes||No||No
     75||'''9.3'''||No||No||No||No||Yes||Yes||Yes||Yes||No
     76||'''9.4'''||No||No||No||No||Yes||Yes||Yes||Yes||Yes?
     77||'''9.5'''||No||No||No||No||No*||Yes||Yes||Yes||Yes
     78||'''9.6'''||No||No||No||No||No*||Yes (not supported, compiles, some tests fail, use only for pg_upgrade)||Yes||Yes||Yes
     79||'''10'''||No||No||No||No||No||No||Yes (2.3.4+ not recommended)||Yes||Yes
     80||'''11'''||No||No||No||No||No||No||No||No*||Yes
    7581
    7682'''Versions of GDAL support for PostGIS'''
