Changes between Version 15 and Version 16 of UsersWikiPostGIS20Debian60pkg
- Oct 25, 2012, 6:57:40 PM (12 years ago)
v15 v16 89 89 Download the two patch files from this page into the scratch directory. 90 90 91 Build Postgis 2.0. This uses the postgis 1.5.3 control files from squeeze. The two patches are applied here to fix an issue with Postgis itself (a bad URL in java/jdbc/build.xml to the maven jar that ant requires for building), and to make the control files build the package. Ensure that both postgis_debian-2.0.1.patch and postgis_maven.patch are in the scratch directory.91 Build Postgis 2.0. This uses the postgis 1.5.3 control files from squeeze. The two patches are applied here to fix an issue with Postgis itself (a bad URL in java/jdbc/build.xml to the maven jar that ant requires for building), and to make the control files build the package. 92 92 {{{ 93 93 wget http://postgis.org/download/postgis-2.0.1.tar.gz 94 wget http://trac.osgeo.org/postgis/raw-attachment/wiki/UsersWikiPostGIS20Debian60pkg/postgis_debian-2.0.1.patch 94 95 tar xvf postgis-2.0.1.tar.gz 95 96 cd postgis-2.0.1
