Changes between Version 2 and Version 3 of TracUnicode
- 04/22/15 15:36:52 (10 years ago)
TabularUnified TracUnicode
v2 v3 2 2 [[TracGuideToc]] 3 3 4 Trac stores all text using UTF-8 encoding, including text in tickets and wiki pages. Internal processing of text uses true Unicode representations.4 Trac encodes all text using [http://en.wikipedia.org/wiki/UTF-8 UTF-8], including text in tickets and wiki pages. Internal processing of text uses true [http://en.wikipedia.org/wiki/Unicode Unicode] representations. As such, it supports most (all?) commonly used character encodings. 5 5 6 As such, it supports most (all?) commonly used character encodings. 6 If the default encoding in your source code repository is not UTF-8, you can specify it in the [TracIni#trac-section trac.ini]: 7 {{{ 8 default_charset = gbk 9 }}} 7 10 8 If your encoding is not UTF-8, you can use [wiki:TracModPython mod_python] to handle it. For example, if your local encoding is gbk, you can set 9 default_charset = gbk 10 in trac.ini. 11 Also ensure that your [trac:DatabaseBackend database] stores its data in UTF-8, otherwise results may be unpredictable. 11 12 12 You also must make sure that your [trac:DatabaseBackend database backend] stores its data in UTF-8; otherwise strange things will happen. 13 14 To convert your database to UTF-8, the easiest way is to dump the database, convert the dump into UTF-8 and then import the converted dump back into the database.[[BR]] 15 You can use [http://www.gnu.org/software/libiconv/documentation/libiconv/iconv.1.html iconv] to convert the dump. 16 13 To convert your database to UTF-8, the easiest way is to create a dump of the database, convert it into UTF-8, for example using [http://www.gnu.org/software/libiconv/documentation/libiconv/iconv.1.html iconv], and then import it back into the database. 17 14 18 15 == Examples ==
