Changes between Version 67 and Version 68 of PostGIS_Raster_SoC_Idea_2012/Distance_Analysis_Tools
07/11/12 21:09:45 (13 years ago)
qliu
  • TabularUnified PostGIS_Raster_SoC_Idea_2012/Distance_Analysis_Tools
    v67 v68
    710710
    711711'''What did you get done this week?'''
    712  * Disscussed with the Mentor, Came up with a final document of "Creating an Euclidean Distance Raster in PostGIS" as below:
    713
    714
    715 '''Creating an Euclidean Distance Raster in PostGIS'''
    716
    717
    718 Objectives
    719
    720 We want to develop a raster/vector integrated approach to generate a distance raster coverage (optionnaly a tiled coverage) from a point coverage (could also be lines or polygons coverage) with some raster specifications, representing the euclidean distance to those points (lines or polygons).
    721
    722 This approach should be reusable and opening the way to further implementation of interpolation raster, since the distance raster is a specific and simpler case of an interpolation raster, in terms of storing the value associated with the nearest point(s) instead of distance to it.
    723
    724
    725 Constraints
    726
    727 1.      The source table of geometries (points, line or polygons) can contain one geometry or many (eventually millions). We want the method to scale well whatever the number of source geometry.
    728 2.      The desired raster is specified with parameters or by referencing an existing raster.
    729 3.      Sometimes the resolution of the desired raster is so high that the whole raster coverage cannot be stored in one PostgreSQL row. The approach must be able to produce a tiled raster coverage stored into many rows.
    730 4.      Source geometries might be outside the extent of the desired raster.
    731 5.      The approach should work well in a number of situations:
    732 a.      small number of sources vs low resolution raster,
    733 b.      small number of sources vs high resolution raster
    734 c.      large number of sources vs low resolution
    735 d.      large number of sources vs high resolution Large raster coverage
    736 6.      The user can specify a maximum distance to the source. When the source is too far from the geometry it gets assigned a nodata value.
    737 7.      We want the implementation to be generic enough to be reused to implement more general interpolation methods like nearest neighbor, IDW, spline or kriging. Otherwise we want it to be generic enough to be reused to implement more general cost distance methods.
    738
    739 Different Envisioned Approaches
    740
    741 1.      The raster source approach - The first approach is similar to what is found in most GIS package. The source points (or geometries) are converted to a raster of sources and this raster is passed to the function. The function iterates over the pixels (or over the source points???) assigning the distance to the nearest point (or assigning minimum values to pixels within a circle progressively growing around each point???).
    742
    743 Converting one or a set of source geometries to one raster can be performed like this in PostGIS:
    744
    745 raster ST_Union(raster ST_AsRaster(source_geom, list of parameters for raster specifications))
    746
    747 The Euclidean distance from each pixel to its nearest source pixel can then be computed using ST_MapAlgebra.
    748
    749                 CREATE FUNCTION euclidean_fct(pos1 integer[], pos2 integer[])
    750 RETURNS float
    751 AS $$
    752 BEGIN
    753 SELECT ST_Distance(ST_Point(pos1), ST_Point(pos2)) as euclidean_dist;
    754         RETURN euclidean_dist;
    755 END;
    756 $$
    757 LANGUAGE 'plpgsql';
    758
    759 CREATE TABLE distcoverage AS
    760 SELECT rid, ST_MapAlgebraFct(rast, 'euclidean_fct(position of computed pixel, position of source point pixel)'::regprocedure) rast
    761 FROM myexistingcoveragetable
    762
    763 Remarks:
    764 ○       In case source table containing only one point (constraint 1), converting source point to raster could utilize ST_AsRaster() to create a raster with the point geometry and raster specifications.
    765 ○       In case source table containing more than one point but the number of source points is small (constraint 5), computing distance could rescan all the source points and assign the shortest distance to the pixel being computed.
    766
    767 Pros
    768 ○       Simplest approach already implemented in other GIS like GRASS.
    769 ○
    770 Cons:
    771 ○       Producing an intermediate raster is costly if the requested raster resolution is very high (constraint 3, 5b & 5d).
    772 ○       ST_Union could be very inefficient at producing the required raster from a large set of geometries and there is no efficient method to produce such a raster right now in PostGIS (constraints 1, 5c & 5d).
    773 ○       It could be very inefficient to rescan all the source points to find the one nearest to the current pixel (constraint 6, 7, 8 & 12). We still have to see how GRASS does this efficiently.
    774 ○       Only rasters which extent contains all the source points could be produced.
    775 ○       This approach does not answer well to the requirement of developing a generic reusable solution for more interpolation needs (constraint 7).
    776
    777 2.      The TIN approach - The second approach involve creating a TIN (triangulated irregular network) from the table of source geometries first and then to use this TIN to determine the nearest neighbors for each pixel.
    778
    779 The TIN is stored temporarily. A function iterating over each pixel determines in which part of the TIN the current pixel falls and determine the triangle corner nearest to the centroid of the pixel.
    780
    781         s
    782
    783 Remarks:
    784 •       Nearest point to pixel could be determined by interesting the pixel centroid with the TIN in order to determine the triangle including the centroid. The nearest point is then determined from the three corner of the triangle.
    785 •       It could also be determined by producing the TIN with the set of point including all the pixel centroid. Would this fasten the search for the nearest neighbor? This is still to determine.
    786 •       Would this work with a table of line or geometries? How do we produce a TIN from a line or polygon coverage?
    787 •       PostGIS might not be ready to produce a TIN from a point coverage.
    788
    789         Pros:
    790 ○       This would work well with a large number of source points (constraints 1, 5c & 5d) since we would not have to  rescan all the source points for each pixel calculation.
    791 ○       This approach fulfills constraint 7 in that it would allow easy implementation of other interpolation methods.
    792 Cons:
    793 ○       We have no idea for now about the algorithm and performance of building TIN from source geometries in PostGIS if the number of source point is very large (Constraint 7 & 8)
    794 ○       Might be very inefficient and a waste of computing TIN in case there is only one point in the source table (Constraint 1) or there are very small number of source points and the requested raster is relatively small too (Constraint 5).
    795
    796 3.      The KNN index approach – The third approach is similar to the second but use the new KNN indexing facilities of PostGIS to determine the nearest neighbor points of each pixel.
    797
    798
    799         CREATE FUNCTION euclidean_fct(raster rast, text dbschema, text sourcetable, text sourcegeomcolumn)
    800 RETURNS float
    801 AS $$
    802 BEGIN
    803       SELECT ST_Distance (ST_GeomFromText('POINT(columnx rowy)',ST_SRID(rast)), ST_Transform(sourcegeom, Find_SRID(dbschema,sourcetable,sourcegeomcolumn), ST_SRID(rast)) as eucliean_dist
    804       FROM sourcetable
    805       ORDER BY $1 <-> $2
    806       LIMIT 1;
    807       RETURN euclidean_dist
    808 END;
    809 $$
    810 LANGUAGE 'plpgsql';
    811
    812 CREATE TABLE distcoverage AS
    813 SELECT rid, ST_MapalgebraFct(rast, 'euclidean_fct(rast, dbschema, sourcetable, sourcegeomcolumn)'::regprocedure) rast
    814 FROM myexistingcoveragetable
    815
    816         Pros:
    817 ○       Source points do not have to be in the raster extent (constraint 4)
    818 ○       Should work well  with large number of source points (constraint 1, 5c & 5d) since we will be using KNN index to find the nearest point.
    819 ○       Make it possible to to createa tiled raster coverage aligned to an existing one (constraint 3)
    820 ○       Opening to be able to reused for further computing interpolation since the method to find neighbors is quite generic.
    821         Cons:
    822 ○       Might not be as light as Approach 1 in case there is only one point in the source table (Constraint 1) or there are very small number of source points and the requested raster is relatively small too (Constraint 5)
    823 ○       Have no idea how to deal with Constraint 9.
    824
    825
    826 Preferred Approach
    827
    828 Approach 3 is the preferred approach for the following reasons:
    829 ●       it exploits and benefits from a very unique and performant new feature of PostGIS: KNN indexing,
    830 ●       it is compliant with PostGIS Raster powerful raster/vector interactions
    831 ●       in terms of scalability, it provides the possibility to generate a distance raster from any coverage of point (however numerous they are) since the time to find the nearest neighbor for each pixel is relatively constant (thanks to the KNN index),
    832 ●       it makes it possible to work with huge tiled coverage (constraint 3) since the extent of the raster is independent of the source extent,
    833 ●       it provides a reusable approach for other types of distances (Constraint 13) and interpolation.
    834
    835 Tentative functions signatures:
    836
    837 Generate a raster having the same alignment as a reference raster:
    838
    839 ST_EuclideanDistance(raster ref, text sourceschema, text sourcetable, text sourcegeomcolumn, text pixeltype, double precision value=1, double precision nodataval=0)
    840
    841 Generate a raster based on raster specifications:
    842
    843 ●       Set the dimensions of the raster by providing the parameters of a pixel size (scalex & scaley and skewx & skewy). The width & height of the resulting raster will be adjusted to fit the extent of the geometry
    844
    845 ST_EuclideanDistance(text dbschema, text sourcetable, text sourcegeomcolumn, double precision scalex, double precision scaley, double precision gridx, double precision gridy, text pixeltype, double precision value=1, double precision nodataval=0, double precision skewx=0, double precision skewy=0)
    846
    847 ●       Fix the dimensions of the raster by providing the dimensions of the raster (width & height). The parameters of the pixel size (scalex & scaley and skewx & skewy) of the resulting raster will be adjusted to fit the extent of the source geometry
    848
    849 ST_EuclideanDistance(text dbschema, text sourcetable, text sourcegeomcolumn, geometry geom, integer width, integer height, double precision gridx, double precision gridy, text pixeltype, double precision value=1, double precision nodataval=0, double precision skewx=0, double precision skewy=0)
    850
    851
    852 For Constraint 6: (just write down the function that takes a reference raster for example)
    853 ST_EuclideanDistance(text dbschema, text sourcetable, text sourcegeomcolumn, raster ref, text pixeltype, double precision value=1, double precision nodataval=0, double precision maxdistance)
    854
     712 * Disscussed with the Mentor, Came up with a final document of "Creating an Euclidean Distance Raster in PostGIS" with the link:
     713[http://trac.osgeo.org/postgis/wiki/PostGIS_Raster_SoC_Idea_2012/Distance_Analysis_Tools/document]
    855714
    856715''' What do you plan on doing next week?'''
