2 | 2 | CREATE TABLE test_source_raster_0 AS SELECT 1 AS rid,rast FROM (SELECT ST_MakeEmptyRaster(10,10,0,0,1,1,0,0,4326) AS rast)foo; |
3 | 3 | CREATE TABLE test_source_geometry_0 AS SELECT generate_series(1,10) AS id,ST_RandomPoints(the_geom,10) AS the_geom FROM (SELECT ST_SetSRID(ST_Extent(rast::geometry),4326) AS the_geom FROM test_source_raster_0)foo; |
4 | 4 | CREATE TABLE test_ref_raster_0 AS SELECT 1 AS rid,rast FROM (SELECT ST_MakeEmptyRaster(10,10,0,0,1,1,0,0,4326) AS rast)foo; |
5 | 5 | |
6 | | '''0-a: Test NULL Raster. Should be true.''' |
7 | | SELECT ST_EuclideanDistance(NULL,NULL,'public','test_source_geometry_0','the_geom',False) IS NULL FROM test_ref_raster_0; |
8 | | |
9 | | '''0-b: Test Empty Raster. Should be true.''' |
10 | | SELECT ST_IsEmpty(ST_EuclideanDistance(0,10,0,0,1,1,0,0,4326,-999,'32BF','public','test_source_geometry_0','the_geom',False)); |
| 6 | 0-a: Test NULL Raster. Should be true. |
| 7 | SELECT ST_EuclideanDistance(NULL,NULL,'public','test_source_geometry_0','the_geom',False) IS NULL FROM test_ref_raster_0; |
| 8 | |
| 9 | 0-b: Test Empty Raster. Should be true. |
| 10 | SELECT ST_IsEmpty(ST_EuclideanDistance(0,10,0,0,1,1,0,0,4326,-999,'32BF','public','test_source_geometry_0','the_geom',False)); |
13 | | '''1-a: Source geometry within the extent of the desired raster:''' |
14 | | CREATE TABLE test_source_raster_1 AS SELECT 1 AS rid,rast FROM (SELECT ST_MakeEmptyRaster(10,10,0,0,1,1,0,0,4326) AS rast)foo; |
15 | | CREATE TABLE test_source_geometry_1 AS SELECT generate_series(1,10) AS id,ST_RandomPoints(the_geom,10) AS the_geom FROM (SELECT ST_SetSRID(ST_Extent(rast::geometry),4326) AS the_geom FROM test_source_raster_1)foo; |
16 | | CREATE TABLE test_ref_raster_1 AS SELECT 1 AS rid,rast FROM (SELECT ST_MakeEmptyRaster(10,10,0,0,1,1,0,0,4326) AS rast)foo; |
17 | | 1-a-i: Generate Euclidean Distance from a one-band reference raster |
18 | | 1-a-i-1: Snap is True; Max distance NOT specified: |
19 | | CREATE TABLE test_eudist_1_a_i_1 AS (SELECT 1 AS rid,ST_EuclideanDistance(rast,'32BF','public','test_source_geometry_1','the_geom',True) AS rast FROM test_ref_raster_1);[[BR]] |
20 | | result:[[BR]] |
21 | | [[Image(test_eudist_1_a_i_1.gif)]][[BR]] |
| 13 | 1-a: Source geometry within the extent of the desired raster: |
| 14 | CREATE TABLE test_source_raster_1 AS SELECT 1 AS rid,rast FROM (SELECT ST_MakeEmptyRaster(10,10,0,0,1,1,0,0,4326) AS rast)foo; |
| 15 | CREATE TABLE test_source_geometry_1 AS SELECT generate_series(1,10) AS id,ST_RandomPoints(the_geom,10) AS the_geom FROM (SELECT ST_SetSRID(ST_Extent(rast::geometry),4326) AS the_geom FROM test_source_raster_1)foo; |
| 16 | CREATE TABLE test_ref_raster_1 AS SELECT 1 AS rid,rast FROM (SELECT ST_MakeEmptyRaster(10,10,0,0,1,1,0,0,4326) AS rast)foo; |
| 17 | 1-a-i: Generate Euclidean Distance from a one-band reference raster |
| 18 | 1-a-i-1: Snap is True; Max distance NOT specified: |
| 19 | CREATE TABLE test_eudist_1_a_i_1 AS (SELECT 1 AS rid,ST_EuclideanDistance(rast,'32BF','public','test_source_geometry_1','the_geom',True) AS rast FROM test_ref_raster_1);[[BR]] |
| 20 | '''result:'''[[BR]] |
| 21 | [[Image(test_eudist_1_a_i_1.gif)]][[BR]] |
