Changes between Version 7 and Version 8 of PostGISExtensionPaths
- Feb 11, 2022, 10:54:41 AM (2 years ago)
v7 v8 82 82 === SOLUTION 3 === 83 83 84 The 0-byte file and strip model. This approach creates 0 or very small byte files, with their exist ingsolely to maintain PostgreSQL extension chain model.85 To reduce file bloat, we will only support the last two micros of any release. Anyone who isn't in the latest micro (or latest to last micro) of each minor/major, with need to upgrade to saidversion OR use the postgis_extensions_upgrade() function.84 The 0-byte file and strip model. This approach creates 0 or very small byte files, with their existense solely to maintain PostgreSQL extension chain model. 85 To reduce file bloat, we will have <version-minor>--<version-minor-curren>MAX files. Anyone who is coming from a prior minor will have a file such as postgis--3.2.1--3.2MAX version OR use the postgis_extensions_upgrade() function. 86 86 87 87 In this model, our extension files look like below: 88 An additional addendum to this SOLUTION 3, is to not maintain - extensions/updateable.mk but instead have this file generated as part of the build process and be shipped as part of the tar ball.89 88 90 The extensions/updateable.mk will be generated by looking at git tags all the prior versions, and picking the last two of each mino. 91 92 our generated extension upgrade scripts will look like the below, with only the postgis--3.3.0MAX--3.3.0.sql having any upgrade statements in it. 89 our generated extension upgrade scripts will look like the below, with only the postgis--3.3MAX--3.3.0.sql having any upgrade statements in it. 93 90 94 91 ---- 95 92 : 96 postgis--3.1 .4--3.3.0MAX.sql97 postgis--3.1.5--3.3 .0MAX.sql98 postgis--3.2 .0--3.3.0MAX.sql99 postgis--3. 2.1--3.3.0MAX.sql100 postgis--3.3.0 MAX--3.3.0.sql93 postgis--3.1MAX--3.3MAX.sql 94 postgis--3.1.5--3.3MAX.sql 95 postgis--3.2MAX--3.3MAX.sql 96 postgis--3.3MAX--3.3.0.sql 97 postgis--3.3.0--3.3MAX.sql 101 98 ---- 102 99 **Benefits of this approach:** 103 100 104 101 1. We are staying between the lines. Respecting known practices, but still having much lighter weight scripts. 105 2. A little less clutter if we include the addendum (of only keeping the last 2) 102 2. A little less clutter, but we are relying on the user having the old version still installed so that they have a chain 103 postgis--<old-version-minor-micro>--<old-version-minor>MAX.sql 106 104 3. A little little easier release cycle if we don't need to maintain extensions/updateable.mk and remember to update it. 107 105 4. No change in upgrade extension workflow for packagers (or users who think of PostGIS as any other extension).
