Changes between Version 20 and Version 21 of PostGIS3
- May 10, 2019, 2:26:53 PM (3 years ago)
PostGIS3
v20 v21 2 2 3 3 This page is not a list of things that **will happen** it is a place to gather disruptive changes that might make sense for a PostGIS 3 release. 4 5 == Tasks ==6 7 * strk and robe to help set up OSGeo7 via Jitsi8 4 9 5 == Done … … 15 11 * Modern GEOS version requirement 16 12 * ST_AsGeoJSON/GeomFromGeoJSON that are aware of json/jsonb types. So, geometry::json is ST_AsGeoJSON(geometry). A documented function to turn a table into GeoJSON FeatureCollection, automagically finding the geometry field; 13 * Support for Proj 6.0, GDAL 3.0 17 14 18 == Ideas 19 20 * Require installation in a 'postgis' schema, always and for ever **HOLD OFF not as important as it used to be now that its not movable** 21 * Yet another serialization, this time changing to use `external` storage type, and adding our own compression scheme for coordinates. 15 == In Progress (most likely will be released in 3.0) 16 * * Yet another serialization, this time changing to use `external` storage type, and adding our own compression scheme for coordinates. 22 17 * An uncompressed header, so header info can always be efficiently "sliced" and read, even for very large objects 23 18 * A hash key for use in fast and small equality comparisons (for use in cached comparison code) … … 25 20 * Other compression formats with other tradeoffs (?) like TWKB for higher ratio with precision loss 26 21 * Implies indirection in coordinate access again: smaller, more efficient must be balanced against direct access to coordinates 22 23 24 == Ideas 25 26 * Require installation in a 'postgis' schema, always and for ever **HOLD OFF not as important as it used to be now that its not movable** 27 27 28 28 29 * Some major GEOS surgery to allow memory management by palloc?
