Changes between Version 22 and Version 23 of GeospatialDataViewerInPgAdmin4ForPostGIS_FinalReport
- 08/05/18 03:17:14 (7 years ago)
TabularUnified GeospatialDataViewerInPgAdmin4ForPostGIS_FinalReport
v22 v23 27 27 1. Clone the [https://github.com/Gooong/pgadmin4/tree/geoviewer geoviewer branch]. 28 28 2. Build and run pgAdmin4 following README.md in the repository. 29 3. {{{cd $PGADMIN4_SRC}}} and run {{{make check-js}}}.30 3. I nstall29 3. For unit test {{{cd $PGADMIN4_SRC}}} and run {{{make check-js}}}. 30 3. If you want to try and test manually, install [https://postgis.net/ PostGIS] and import some geometry data (for example import [https://drive.google.com/open?id=1NHWW4WPli7kxpuGaDFGVFLDXdc2D20wp this database] using [https://www.postgresql.org/docs/9.2/static/app-psql.html psql]). Then execute query in the pgAdmin4 and view the results. 31 31 32 32 == Future Work
