12 | | We are working on similar chain for 32-bit installation. |
| 12 | We are working on similar chain for 32-bit installation but currently doesn't work for MingW64 32-bit chain. |
| 13 | Also there are issues with GEOS compile about 4.5.4 or so, in 4.6.1+, the make check crashes and so does |
| 14 | PostGIS tests when compiled with GCC 4.6+. That said you should pick a build lower than GCC 4.6. |
| 15 | Issues are documented in http://trac.osgeo.org/geos/ticket/518 (also similar issue compiling Geso under windows 64-bit SDK http://trac.osgeo.org/geos/ticket/528 ) |
