Changes between Version 49 and Version 50 of DevWikiGardenTest
- Dec 3, 2010, 7:29:36 AM (14 years ago)
DevWikiGardenTest
v49 v50 26 26 If the test crashes before completion, the record with the max logid will tell you the query that crashed the server. 27 27 28 * '''postgis_garden_log_output''' -- this outputs the query results for queries that return something in xml format. It uses the built-in query_to_xml function that has existed since PostgreSQL 8.3 to do that. 29 columns: 28 * '''postgis_garden_log_output''' -- this outputs the query results for queries that return something in xml format. It uses the built-in query_to_xml function that has existed since PostgreSQL 8.3 to do that. columns: 30 29 * ''logid'' - you can join this with the postgis_garden_log table to get the descriptive detail and SQL for the test. 31 30 * ''log_output'' - an xml field that contains the query_to_xml output of the query.
