Changes between Initial Version and Version 1 of Ticket #689
- Dec 8, 2010, 3:14:20 PM (14 years ago)
Ticket #689 – Description
initial v1 12 12 {{{ 13 13 14 "SELECT ST_CoveredBy(foo1.the_geom, foo2.the_geom) As result, ST_AsText(foo1.the_geom) As ref1_geom, ST_AsText(foo2.the_geom) As ref2_geom14 SELECT ST_CoveredBy(foo1.the_geom, foo2.the_geom) As result, ST_AsText(foo1.the_geom) As ref1_geom, ST_AsText(foo2.the_geom) As ref2_geom 15 15 FROM ((SELECT ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326) As the_geom 16 16 UNION ALL SELECT ST_GeomFromText('POLYGON EMPTY',4326) As the_geom … … 19 19 UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON EMPTY',4326) As the_geom 20 20 UNION ALL SELECT ST_GeomFromText('LINESTRING EMPTY',4326) As the_geom 21 UNION ALL SELECT ST_GeomFromText('MULTILINESTRING EMPTY',4326) As the_geom ) ) As foo1 CROSS JOIN ((SELECT ST_MakeLine(ST_SetSRID(ST_MakePointM(i,j,m),4326),ST_SetSRID(ST_MakePointM(j,i,m),4326)) As the_geom FROM generate_series(-10,50,10) As i CROSS JOIN generate_series(50,70, 20) As j CROSS JOIN generate_series(1,2) As m WHERE NOT(i = j) ORDER BY i, j, m, i*j*m)) As foo2 ;21 UNION ALL SELECT ST_GeomFromText('MULTILINESTRING EMPTY',4326) As the_geom ) ) As foo1 CROSS JOIN ((SELECT ST_MakeLine(ST_SetSRID(ST_MakePointM(i,j,m),4326),ST_SetSRID(ST_MakePointM(j,i,m),4326)) As the_geom FROM generate_series(-10,50,10) As i CROSS JOIN generate_series(50,70, 20) As j CROSS JOIN generate_series(1,2) As m WHERE NOT(i = j) ORDER BY i, j, m, i*j*m)) As foo2 LIMIT 2; 22 22 }}}
