Changes between Version 1 and Version 2 of Ticket #5808
- 11/05/24 12:46:29 (8 weeks ago)
Ticket #5808 – Description
v1 v2 53 53 My extensions seems to need some update (? still can't find how to get rid of that message, alter extension or the upgrade functions seems do not help here, but is other issue. 54 54 55 ``` 55 {{{ 56 56 SELECT PostGIS_Full_Version(); 57 57 58 58 POSTGIS="3.5.0 POSTGIS_REVISION" [EXTENSION] PGSQL="160" GEOS="3.12.1-CAPI-1.18.1" PROJ="9.4.1 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.12.1) GDAL="GDAL 3.9.1, released 2024/06/22" LIBXML="2.12.7" LIBJSON="0.17" LIBPROTOBUF="1.5.0" WAGYU="0.5.0 (Internal)" (core procs from "3.5.0 d2c3ca4" need upgrade) TOPOLOGY (topology procs from "3.5.0 d2c3ca4" need upgrade) RASTER (raster procs from "3.5.0 d2c3ca4" need upgrade) 59 ``` 59 }}}
