Changes between Initial Version and Version 1 of Ticket #5740
06/11/24 19:35:09 (12 months ago)
cdestigter
  • Ticket #5740 – Description
    initial v1
    33> Returns minimum distance in meters between two lon/lat geometries given a particular spheroid
    44
    5 Based on this description it seems that any intersection between the two geometries to cause the result to be 0 (the minimum distance between the geometries is 0 because they overlap)
     5Based on this description it seems that any intersection between the two geometries should cause the result to be 0 (the minimum distance between the geometries is 0 because they overlap)
    66
    7 However, perhaps it actually compares the _edges_ of the geometries and so if one geometry contains the other you get a positive number:
     7However, it seems that actually compares the _edges_ of the geometries - if one geometry contains the other you get a positive number:
    88
