Changes between Initial Version and Version 1 of Ticket #3940
12/11/17 20:59:06 (7 years ago)
robe
  • Ticket #3940 – Description
    initial v1
    88{{{
     904:48:26  -------------- Dependencies --------------
     1004:48:26   GEOS config:          /usr/local/bin/geos-config
     1104:48:26   GEOS version:         3.6.2
     1204:48:26   GDAL config:          /usr/local/bin/gdal-config
     1304:48:26   GDAL version:         2.2.2
     1404:48:26   SFCGAL config:        /usr/local/bin/sfcgal-config
     1504:48:26   SFCGAL version:       1.3.1
     1604:48:26   PostgreSQL config:    /usr/local/bin/pg_config
     1704:48:26   PostgreSQL version:   PostgreSQL 10.1
     1804:48:26   PROJ4 version:        49
     1904:48:26   Libxml2 config:       /usr/local/bin/xml2-config
     2004:48:26   Libxml2 version:      2.9.4
     2104:48:26   JSON-C support:       no
     2204:48:26   protobuf-c support:   no
     2304:48:26   PCRE support:         no
     2404:48:26   Perl:                 /usr/local/bin/perl
     2504:48:26
     2604:48:26  --------------- Extensions ---------------
     2704:48:26   PostGIS Raster:       enabled
     2804:48:26   PostGIS Topology:     enabled
     2904:48:26   SFCGAL support:       enabled
     3004:48:26   Address Standardizer support:       disabled
     3104:48:26
     3204:48:26  -------- Documentation Generation --------
     3304:48:26   xsltproc:             /usr/local/bin/xsltproc
     3404:48:26   xsl style sheets:
     3504:48:26   dblatex:
     3604:48:26   convert:              /usr/local/bin/convert
     3704:48:26   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
     38
    93904:50:54  out_geometry .. failed (diff expected obtained: /home/jenkins/tmp/pgis_reg_trunk/test_55_diff)
    104004:50:54 -----------------------------------------------------------------------------
