Changes between Initial Version and Version 2 of Ticket #2580
- 12/18/13 07:22:48 (11 years ago)
Ticket #2580
- Property Summary CREATE EXTENSION allows installing postgis twice → postgis should only be allowed to be installed only once per database
TabularUnified Ticket #2580 – Description
initial v2 1 It is currently possible to install PostGIS twice if installed in separate schemas. This is more of an issue if people use the old way (install in public schema for example ) and then try to install with CREATE EXTENSION in a non-public schema. never an issue with a pure CREATE EXTENSION since CREATE EXTENSION postgis can only be run once per database regardless of schema it is installed in. 2 1 3 See IRC transcript below... 2 4
