Changes between Version 2 and Version 7 of Ticket #1247
- 10/29/24 02:04:24 (5 months ago)
Ticket #1247
- Property Milestone PostGIS Raster Future → PostGIS 3.6.0
- Property Summary ST_AsRaster aggregate function → [raster] ST_AsRaster aggregate function
- Property Component postgis → raster
- Property Owner changed from to
- Property Status new → assigned
TabularUnified Ticket #1247 – Description
v2 v7 3 3 Not sure if this is what you had in mind when you said "Burn In" function in your talk. A common need I have which I am sure is that of many BI analysts is the need to show simple thematic maps in reports. 4 4 5 What came to mind to me was an aggregate ST_AsRaster function that takes a set of geomval rows (or multicolumn geom, value) and builds a raster. Basically a reverse of the ST_DumpAsPolgonsfunction.5 What came to mind to me was an aggregate [https://www.postgis.net/docs/manual-dev/RT_ST_AsRaster.html ST_AsRaster] function that takes a set of geomval rows (or multicolumn geom, value) and builds a raster. Basically a reverse of the [https://www.postgis.net/docs/manual-dev/RT_ST_DumpAsPolygons.html ST_DumpAsPolgons] function. 6 6 7 http://www.postgis.org/documentation/manual-svn/RT_ST_AsRaster.html 7 8 8 This would make it trivial to do a query such as 9 9
