2 | | ESRI Shapefile cutter |
3 | | {{{ |
4 | | USAGE: shputils <DescribeShape> |
5 | | USAGE: shputils <InputShape> <AppendShape> |
6 | | { <SELECT> <Item> <valuelist> } |
7 | | { <UNSELECT> <Item> <valuelist> } |
8 | | { <CLIP> <xmin> <ymin> <xmax> <ymax> <TOUCH|INSIDE|CUT> } |
9 | | { <CLIP> <Theme> <BOUNDARY|POLYGON> <TOUCH|INSIDE|CUT> } |
10 | | Clip functions for Cut and Polygon are not supported yet... |
11 | | { <ERASE> <xmin> <ymin> <xmax> <ymax> <TOUCH|INSIDE|CUT> } |
12 | | { <ERASE> <Theme> <BOUNDARY|POLYGON> <TOUCH|INSIDE|CUT> } |
13 | | { <UNIT> <FEET|METERS|factor> } |
14 | | { <SHIFT> <xshift> <yshift> } |
| 2 | ESRI Shapefile cutter. This application has been deprecated. Use [wiki:orthoigen] instead. |
| 33 | |
| 34 | {{{ |
| 35 | USAGE: shputils <DescribeShape> |
| 36 | USAGE: shputils <InputShape> <AppendShape> |
| 37 | { <SELECT> <Item> <valuelist> } |
| 38 | { <UNSELECT> <Item> <valuelist> } |
| 39 | { <CLIP> <xmin> <ymin> <xmax> <ymax> <TOUCH|INSIDE|CUT> } |
| 40 | { <CLIP> <Theme> <BOUNDARY|POLYGON> <TOUCH|INSIDE|CUT> } |
| 41 | Clip functions for Cut and Polygon are not supported yet... |
| 42 | { <ERASE> <xmin> <ymin> <xmax> <ymax> <TOUCH|INSIDE|CUT> } |
| 43 | { <ERASE> <Theme> <BOUNDARY|POLYGON> <TOUCH|INSIDE|CUT> } |
| 44 | { <UNIT> <FEET|METERS|factor> } |
| 45 | { <SHIFT> <xshift> <yshift> } |
| 46 | |
