| 1 | |
| 2 | == **OSSIM Command Line Interface** |
| 3 | |
| 4 | Provides access to many high-level functions available in OSSIM and associated plugins. |
| 5 | |
| 6 | Usages: |
| 7 | ossim-cli <command> [command options and parameters] \\ |
| 8 | ossim-cli --spec <command-spec-file>\\ |
| 9 | ossim-cli --version\\ |
| 10 | ossim-cli help <command> -- To get help on specific command. |
| 11 | |
| 12 | Available commands: |
| 13 | |
| 14 | atp -- Provides automatic tiepoint generation functionality. This tool uses JSON format to communicate requests and results.\\ |
| 15 | bandmerge -- Merges multiple band files into a single RGB image.\\ |
| 16 | dem -- Provides DEM generation functionality. This tool uses JSON format to communicate requests and results.\\ |
| 17 | hillshade -- Computes shaded representation of input elevation surface with specified lighting parameters.\\ |
| 18 | hlz -- Computes bitmap of helicopter landing zones given ROI and DEM.\\ |
| 19 | info -- Dumps metadata information about input image and OSSIM in general.\\ |
| 20 | ortho -- Utility for orthorectifying and reprojecting image data.\\ |
| 21 | pointcloud -- Utility class for generating point-cloud-derived image products.\\ |
| 22 | potrace -- Computes vector representation of input raster image.\\ |
| 23 | remap -- Performs remap to 8-bit including optional histogram stretch and saves the corresponding external geometry file.\\ |
| 24 | shoreline -- Computes bitmap of water versus land areas in an input image.\\ |
| 25 | slope -- Utility for computing the slope at each elevation post and generating a corresponding slope image.\\ |
| 26 | subimage -- Tool for extracting a sub-image from a full image. No reprojection is done. Presently, the subimage geometry is represented by an RPC replacement model until generic models can support subimage chipping.\\ |
| 27 | vertices -- Utility for determining the active image corner vertices inside larger null-filled image rectangle.\\ |
| 28 | viewshed -- Computes bitmap image representing the viewshed from specified location using only DEM information. |
| 29 | |
| 30 | ossim-cli provides a "tool" plugin design that enables high-level functionality to be included via plugin libraries. The plugin will need to register the tool (i.e., the class executing the functionality) with the tool registry. |
| 31 | |
