Changes between Version 4 and Version 5 of icp
- Oct 15, 2010, 4:49:25 AM (14 years ago)
icp
v4 v5 1 1 = icp = 2 2 3 The ossim-icp application is an image conversion tool used to copy any supported input image to any supported output image format. It can also crop by start/stop line/sample, band select and convert scalar type. If you wish to resample or reproject your data,use [wiki:orthoigen] instead.3 The ossim-icp application is an image conversion tool used to translate an input image to another format (e.g. TIF to JPG). It can also be used to crop, band select and convert scalar type. If you wish to resample or reproject your data, please use [wiki:orthoigen] instead. 4 4 5 5 The iView GUI application operates as a viewer and a way to set up parameters for icp. icp can be called from the command line or from an application - e.g. iView. … … 83 83 ''ossim-icp ossim_kakadu_jp2 point.tif t1.jp2''[[BR]] 84 84 85 86 85 This will convert point.tif to a numerically lossless jp2 file.[[BR]] 87 86 ''ossim-icp --writer-prop compression_quality=numerically_lossless ossim_kakadu_jp2 point.tif t1.jp2''[[BR]]
