Changes between Version 101 and Version 102 of WikiStart
- Oct 18, 2010, 4:23:23 PM (14 years ago)
WikiStart
v101 v102 21 21 22 22 <ul> 23 <li>Precision Terrain correction and orthorectification</li>24 <li>Advanced Mosaicing, compositing, and fusions</li>23 <li>Precision terrain correction and orthorectification</li> 24 <li>Advanced mosaicing, compositing, and fusion</li> 25 25 <li>Histogram matching and tonal balancing</li> 26 26 <li>Rigorous sensor modeling</li> 27 <li>Universal Sensor Models (RPCs)</li> 28 <li>Wide range of Map Projections and Datums supported</li> 29 <li>Non-destructive, parameter based image chains</li> 27 <li>Parameter based image chains</li> 30 28 <li>Native file access</li> 31 29 <li>Elevation support</li> 32 <li>Vector and shapelib support</li> 33 <li>Projection and resolution independent</li> 34 <li>Equation editors</li> 35 <li>Parallel processing capabilities with mpi libraries</li> 30 <li>Vector support</li> 36 31 </ul> 37 32
