Changes between Version 3 and Version 4 of WeekReport
06/21/09 10:16:53 (16 years ago)
epifanio
  • WeekReport
    v3 v4
    6464
    6565== ==
     66
     67== Report 2  ==
     68
     69Hi All,
     70
     71apologize me for the gap time :-/
     72
     73the "duplicate grass installation" gived me some problems.
     74Fixed the gdal-grass driver problems (thanks to William!!!) when multiple grass installation are finded
     75now the problem come up with subprocess when i use the grass.py function
     76
     77the error is a bit weird beacouse it sometimes works and sometimes get me a subprocess error
     78
     79^^^ this only on Osx ...  on linux all goes fine.
     80
     81
     82... so : hard solution, i erased an exrternal hd and installed osx from scratch with only one grass version(7) i haven't finished to reinstall all the needed SW
     83
     84
     85back to coding ...
     86
     87going ahed with my coding ... what i do this week :
     88
     89- worked a lot to have a better gui.
     90  to have a more usable app. i switched from Qwidjet() to Qmainwindow() so now i'm able to use more widjet like menubar etc... (i know this are cosmetics things ;-)
     91
     92- worked on the kml export, not uploaded yet into the svn
     93  i have kml export working for point line and polygon, but i haven't yet it working on polygon that has inner+outher boundaries.
     94  it use py-gdal to have acces to the layer feature
     95
     96  the export parameters are :
     97
     98  colors (line,label,polygon)
     99  alpha-chanell(colors)
     100  line width
     101  altitude mode
     102  icons
     103
     104  label name and height can be setted from a field attribute
     105
     106  (studing the kml standard)
     107
     108   i'm including the layer attributes in the "kml data description", but my plain is to insert , in the kml attribute data,
     109   the results of v.what + r.what (for points and/or polygon's centroid)
     110  for line i think is not usefull .. maybe leght and layer attributes can be good as information.
     111
     112  the layers to be queried are the layer in the active mapset
     113  (in the gui i'm adding a tree with layer's names, each layer will be checkable so all the checked layer will be passed to the query)
     114
     115  i need to add yet the capabilites to create png file for raster legend so we can the kml export to create "kml screen overlay"
     116  i think to use the png monitor in grass to produce the image or other solution .. i need to investigate
     117
     118-  wrotin build documentation about my linux environment.
     119   starting from a linux live cd distro (sidux) i done an "how to install" (apt-get & configure notes) for all the sw i'm using
     120   so i create a virtualcd based on virtualbox i can distribuite to every one want help me to test the project
     121   (the project has immense options of development so suggestions on which    feature is to prefer to an other one
     122    or you have a feature that is possible to include in it and and i haven't tinked yet)
     123
     124-  On the next week the OssimDev Team will have a meeting, so i'm preparing a report with case-test to face the ossm-gdal-grass   raster rendering.
     125
     126== ==
     127
     128== Report 3  ==
     129
     130Little notes :
     131
     132Restored my OS,
     133
     134for grass on osx i'm using version 6.4
     135(the 7 can works, but some time the build fais, so to have a more stable development
     136i'm switching to 6,4 binary version, so it is more easy for osx user to test the code)
     137
     138on linux i'using grass7 (there are difference in the module import for grass, so i'll use "try: except"
     139to get the code running for grss 6.4 and 7)
     140
     141
     142Coded :
     143
     144fixed the polygons exporte to kml so now hole in polygons hare andled
     145firex some gui behavioure .. a window too much big, so i done a recode of the gui code
     146
     147- preparing a different web-map widjet, based on ka-map2
     148 this can give some enanchement like :
     149 - ability to crteate a mapfile on the fly, generated reading the grass mapset layers
     150 - better refresh of gps signal
     151
     152- done a report about the grass-raster rendering, this tasks will be faced the next week,
     153 i have exam on 16 june so the incoming week my Soc works will be slowly
     154 (i hope all goes well) then i'm planning to go to bolsena meeting where i'll spend
     155  a full dept week to code.
     156
     157here some screenshoot  of the gui (yet prototipe) :
     158
     159http://www.geofemengineering.it/data/view.png
     160http://www.geofemengineering.it/data/data.png
     161http://www.geofemengineering.it/data/gps.png
     162
     163for who is intersted in testing, debug :
     164
     165-  notes about the installation of the needed software can be etracted from :
     166
     167http://wiki.osgeo.org/wiki/GFOSS.it_Live_DVD_Install
     168
     169
     170done a virtual machine with needed sw,
     171but my ftp reject it :-(
     172so i don't know where to upload it
     173(this is for who is intersted in testing purpose, but has problems / or do not want touch his system)
     174
     175== ==
     176
     177== Report 4  ==
     178
     179Hi All,
     180
     181here the 4-th report for my project :
     182
     183In the last week, after some coding i can see that he main-app file was too much long
     184that is no good beacouse the code is not easy readable.
     185
     186doing some  test, i can see the threaded class "joystick and gps tools"
     187consume a lot of cpu-resource
     188
     189i decided to do a complete revision on the code :
     190
     191- extracted some function and class from the main file
     192  and store it in separate files (the code results more readable,
     193  and each tools can be easy re-used out-side the main app)
     194
     195- done a complete revision on the trheaded class,
     196  now the trhead are colled only when they really needs
     197  i also added in the joystick code a line used in pygame
     198  to reduce cpu usage when possible.
     199
     200
     201The results code is more fast and readable.
     202
     203In the last week i also worked on :
     204
     205- a query tool to ask information on grass layer (both raster and vector)
     206  it runs r.what + v.what on  a list of selectable layers avaiable in the active grass-mapset.
     207
     208- initial test about the grass code to produce "legend images"  for raster layers
     209  this is needed to produce kml screen overlay
     210
     211- create a blog page for the project to describe the project
     212
     213
     214what to do  the next week :
     215
     216- separate each tool in separate files produce some (minor) code issue, i need to learn how to send
     217  a message from one widget to an other one (e.g. create connections bettween different tools)
     218  if some one has pyqt knowledge i have some questions for him ;-)
     219
     220- rework the web-map based tool using kamap2 (it will consists in a web-gis based on a mapfile produced on the fly, it read the layer to render from a list of grass layer, so i'm coding an interface to produce it)
     221
     222- i'll be in Bolsena for the osgeo hacking event i'll try to receive feedback, suggestion for a full coding-week
     223
     224== ==
