Changes between Version 2 and Version 3 of WeekReport
- May 29, 2009, 9:40:42 AM (15 years ago)
WeekReport
v2 v3 15 15 so the position message can be sended using gui, gps, joystick 16 16 17 - code to read the grass environment and retrieve a list for vector, raster and regions in the running mapset 18 so it is possible to syncronize the posiotion in ossimplanet on the center of the active grass region or change the region to a speciphic layer or saved region 17 - code to read the grass environment and retrieve a list for vector, raster and regions in the running mapset so it is possible to syncronize the posiotion in ossimplanet on the center of the active grass region or change the region to a speciphic layer or saved region 19 18 20 19 - code to export grass elevation data to ossimplanet (g.ossim) the code is usable from the pyqt gui or directly from grass (finished)
