Changes between Version 29 and Version 30 of Ubuntu-7.10Build
- Dec 29, 2008, 12:56:46 PM (16 years ago)
Ubuntu-7.10Build
v29 v30 3 3 4 4 5 6 7 8 # do an Update : 5 # add thes line to /etc/apt/sources.list 6 7 8 echo "deb http://ppa.launchpad.net/jef-norbit/ubuntu intrepid main" >> /etc/apt/sources.list 9 echo "deb-src http://ppa.launchpad.net/jef-norbit/ubuntu intrepid main" >> /etc/apt/sources.list 10 11 # do an Update : 9 12 10 13 sudo apt-get update 11 14 sudo apt-get upgrade 12 15 16 17 # it give you an updated gdal version 18 # with it you can install a development version of qgis too 19 # apt-get install qgis 20 13 21 # Install some libraries : 14 22 15 23 16 apt-get install libqt4-core libqt4-dev libqt4-gui libqt4-qt3support lsb-qt4 qt4-dev-tools qt4-doc qt4-qtconfig uim-qt gdal-bin libgdal1-dev libgeos-dev proj libgdal-doc libtiff4-dev subversion make g++ g++-4.1 gcc libgeotiff1.2 libgeotiff-dev libgeotiff-epsg libopenscenegraph6 libopenscenegraph-dev openscenegraph 17 24 apt-get install libqt4-core libqt4-dev libqt4-gui libqt4-qt3support lsb-qt4 qt4-dev-tools qt4-doc qt4-qtconfig uim-qt gdal-bin libgdal1-dev libgeos-dev proj libgdal-doc libtiff4-dev subversion make g++ g++-4.1 gcc libgeotiff1.2 libgeotiff-dev libgeotiff-epsg cmake 25 26 27 # download Openscenegraph from source : 28 29 svn co http://www.openscenegraph.org/svn/osg/OpenSceneGraph/tags/OpenSceneGraph-2.6.1 OpenSceneGraph 30 31 cd Op 32 mkdir build 33 cd build 34 ccmake .. # delete the not-find libraries from the cmake setting-lines 35 press c 36 press g 37 make 38 sudo make install 39 18 40 # download and install ffmpeg : 19 41 … … 57 79 58 80 59 60 61 62 63 64 81 65 82 # download ossim … … 90 107 91 108 echo "export OSSIM_INC_DIR=/home/sasha/GIS/ossim/ossim/include" >> /home/sasha/.bashrc 92 93 94 95 109 96 110 … … 107 121 108 122 109 ./configure --with-geotiff=/usr/include/geotiff --prefix=/usr --datadir=/usr/share/ossim --includedir=/usr/include/ossim 110 111 --with-jpeg=/usr --with-libtif 112 113 make 114 115 sudo make install 123 ./configure --with-geotiff=/usr/include/geotiff --prefix=/usr --with-jpeg=/usr --with-libtif 124 125 make 126 127 sudo make install 128 129 [http://www.geofemengineering.it/libwms.patch libwms_patch] 130 131 132 # save the patch as libwms.patch 133 # and run : 134 116 135 117 136 cd /home/sasha/GIS/ossim/libwms 118 137 138 patch < /path/to/libwms.patch 139 119 140 make 120 141
