Changes between Version 51 and Version 52 of OSSIMCommandLine
- Oct 19, 2010, 11:56:38 AM (14 years ago)
OSSIMCommandLine
v51 v52 15 15 == Utilities to Create Support Files == 16 16 The following tools are used to create OSSIM [wiki:SupportFiles support files]: 17 * [wiki:applanix2ogeom ossim-applanix2ogeom] Used to create a geom file for Applanix Images. 18 * [wiki:cmm ossim-cmm] Used to determine the min/max pixel values of an image. 19 * [wiki:create_cg ossim-create-cg] Used to create an ossim coarse grid. 20 * [wiki:create_histo ossim-create-histo] Used to compute a histogram for an image. 21 * [wiki:ecg2ocg ossim-ecg2ocg] Used to convert an enhanced coarse grid to an ossim coarse grid. 22 * [wiki:extract_vertices ossim-extract-vertices] Used to compute the valid vertices (corners) of an image. 23 * [wiki:img2md ossim-img2md] Used to create meta data files. 17 24 * [wiki:img2rr ossim-img2rr] Used to create reduced resolution data sets for an image. 18 * [wiki:create_histo ossim-create-histo] Used to compute a histogram for an image. 19 * [wiki:cmm ossim-cmm] Used to determine the min/max pixel values of an image. 20 * [wiki:tfw2ogeom ossim-tfw2ogeom] Used to create a geom file from a TIFF World File 21 * [wiki:applanix2ogeom ossim-applanix2ogeom] Used to create a geom file for Applanix Images. 22 * [wiki:create_cg ossim-create_cg] Used to create an ossim coarse grid. 23 * [wiki:ecg2ocg ossim-ecg2ocg] Used to convert an enhanced coarse grid to an ossim coarse grid. 24 * [wiki:extract_vertices ossim-extract-vertices] Used to compute the valid vertices (corners) of an image. 25 * [wiki:tfw2ogeom ossim-tfw2ogeom] Used to create a geom file from a TIFF World File. 25 26 26 27 == Misc Utilities == 27 28 * [wiki:bilsplitter ossim-bilsplitter] Splits a Band Interleaved by Line (BIL) file into multiple output files. 28 * [wiki:bmvstager ossim-bmvstager]29 29 * [wiki:btoa ossim-btoa] Binary to ASCII conversion. 30 30 * [wiki:chgkwval ossim-chgkwval] Changes the keyword value within a spec file or keyword list. 31 31 * [wiki:correl ossim-correl] 32 32 * [wiki:extract_vertices ossim-extract-vertices] Used to compute the valid vertices (corners) of an image. 33 * [wiki:ossim-foo]34 33 * [wiki:ossim-modopt] 35 * [wiki:mosaic ]34 * [wiki:mosaic ossim-mosaic] 36 35 * [wiki:pixelflip ossim-pixelflip] Converts pixel values. Used for fixing null values. 37 36 * [wiki:prune ossim-prune] Displays if image is null or not.
