58 | | OSSIM_DEV_HOME=~/ossim-svn/src |
59 | | OSSIM_INSTALL_PREFIX=~/ossim-svn/release |
60 | | OSSIM_DEPENDENCIES=/Users/Shared/Development/ossim_dependencies |
61 | | PATH=$OSSIM_INSTALL_PREFIX/bin:$PATH |
62 | | LD_LIBRARY_PATH=$OSSIM_INSTALL_PREFIX/lib:$OSSIM_DEPENDENCIES/lib: |
63 | | DYLD_FRAMEWORK_PATH=$OSSIM_INSTALL_PREFIX/Frameworks:$OSSIM_DEPENDENCIES/Frameworks :$DYLD_FRAMEWORK_PATH |
| 58 | export OSSIM_DEPENDENCIES=/Users/Shared/Development/ossim_dependencies |
| 59 | export OSSIM_DEV_HOME=~/ossim-svn/src |
| 60 | export OSSIM_INSTALL_PREFIX=~/ossim-svn/release |
65 | | DYLD_LIBRARY_PATH=$OSSIM_INSTALL_PREFIX/lib:$OSSIM_DEPENDENCIES/lib |
66 | | DYLD_LIBRARY_PATH=$DYLD_LIBRARY_PATH:$OSSIM_DEPENDENCIES/kakadu/bin |
67 | | DYLD_LIBRARY_PATH=$DYLD_LIBRARY_PATH:$WXMAC_HOME/lib:$PG_HOME/lib:$OSSIM_DEV_HOME/oms/joms:/Developer/qt/lib |
| 62 | DYLD_FRAMEWORK_PATH=$OSSIM_BUILD_DIR/$OSSIM_BUILD_TYPE:$OSSIM_INSTALL_PREFIX/Frameworks:$OSSIM_DEPENDENCIES/Frameworks:$DYLD_FRAMEWORK_PATH |
| 63 | export PATH=$OSSIM_BUILD_DIR/$OSSIM_BUILD_TYPE:$OSSIM_INSTALL_PREFIX/bin:$OSSIM_DEPENDENCIES/bin:$HOME/lsof_4.82_src:$JMETER_HOME/bin:$WXMAC_HOME:$PG_HOME/bin: |
| 64 | export DYLD_LIBRARY_PATH=$OSSIM_BUILD_DIR/$OSSIM_BUILD_TYPE:$OSSIM_INSTALL_PREFIX/lib:$OSSIM_DEPENDENCIES/lib::$OSSIM_DEPENDENCIES/kakadu/lib:$WXMAC_HOME/lib:$PG_HOME/lib:$OSSIM_DEV_HOME/oms/joms:$DYLD_LIBRARY_PATH:/Developer/qt/lib |
| 65 | export LD_LIBRARY_PATH=$OSSIM_BUILD_DIR:$OSSIM_INSTALL_PREFIX/lib:$PG_HOME/lib:$OSSIM_DEV_HOME/oms/joms:$LD_LIBRARY_PATH:/opt/local/lib |
