Changes between Version 24 and Version 25 of ACompletePhotogrammetricOSSIMtoolForAutomaticDSMenerationUsingMultiViewOpticalAndSARimages
08/07/16 14:33:37 (8 years ago)
martidi
  • ACompletePhotogrammetricOSSIMtoolForAutomaticDSMenerationUsingMultiViewOpticalAndSARimages
    v24 v25
    285285At the moment I am not blocked on anything.
    286286
     287
     288
     289[[BR]]
     290=== Weekly Report 11 (07th August, 2016) ===
     291
     292WHAT I GOT DONE THIS WEEK:
     293
     294I have implemented the DSMs fusion on the basis of mean and standard deviation of ascending and descending stacks and of the automated generated masks for foreshortening and layover areas in SAR images.
     295
     296
     297[[BR]]
     298WHAT I PLAN ON DOING NEXT WEEK:
     299
     300To switch from the mean calculation to the median in the masks weight for DSMs merging.
     301
     302To continue testing the code to check if it correctly works also in morphologically complex areas.
     303
     304To test and control implementation efficacy – discuss results with mentors.
     305
     306
     307[[BR]]
     308SOMETHING ON WHICH I AM BLOCKED:
     309
     310At the moment I have a problem with masks generation (sometimes wrong masks are created) and DSMs generation (wrong horizontal lines are generated in the DSMs) but I'm already working to fix it.
     311
