Changes between Version 5 and Version 6 of TracModPython
09/05/24 07:04:12 (7 months ago)
  • TabularUnified TracModPython
    v5 v6
    8383PythonOption TracEnvIndexTemplate /srv/www/htdocs/trac/project_list_template.html
    8484
    85 # A space delimitted list, with a "," between key and value pairs.
     85# A space delimited list, with a "," between key and value pairs.
    8686PythonOption TracTemplateVars key1,val1 key2,val2
    8787
    245245}}}
    246246
    247 === Expat-related segmentation faults === #expat
    248
    249 This problem will most certainly hit you on Unix when using Python 2.4.
    250 In Python 2.4, some version of [http://expat.sourceforge.net/ Expat] (an XML parser library written in C) is used and if Apache is using another version, this results in segmentation faults.
    251 As Trac 0.11 is using Genshi, which will indirectly use Expat, that problem can now hit you even if everything was working fine before with Trac 0.10. This problem has not been reported for Python 2.5+, so best to upgrade.
    252
    253247=== Form submission problems
    254248
