Changes between Version 4 and Version 5 of TracAccessibility
8 May 2022, 15:12:42 (13 months ago)
  • TracAccessibility
    v4 v5
    11= Accessibility Support in Trac
    3 Not every user has a graphic environment with a mouse or other pointing device. Some users rely on keyboard, alternative keyboard or voice input to navigate links and activate form controls. In a Trac session, users can use devices other than a pointing device by enabling keyboard shortcuts through the [/prefs/keybindings Keyboard Shortcuts] preferences panel.
    5 Trac supports accessibility keys for the most common operations. The access keys differ by browser and the following work for several browsers:
    6  - on Linux platforms, press any of the keys listed below in combination with the `<Alt>` key
    7  - on a Mac, use the `<Ctrl>` + `<Opt>` key instead
    8  - on Windows, you need to hit `<Shift> + <Alt> + <Key>`. This works for the most common browsers, such as Firefox, Chrome, Safari and Internet Explorer
    10 Also see [wikipedia:Access_key#Access_in_different_browsers access in different browsers] for more details.
     3Not every user has a graphic environment with a mouse or other pointing device. Some users rely on a keyboard, alternative keyboard or voice input to navigate links and activate form controls. In a Trac session, users can use a device other than a pointing device by enabling keyboard shortcuts through the [/prefs/userinterface Keyboard Shortcuts] preferences panel.
    114
    125== Global Access Keys
     7The global access keys differ by browser and the following work for several browsers:
     8 - on Linux, press any of the keys listed below in combination with the `<Alt>` key
     9 - on a Mac, use `<Ctrl>` + `<Opt>` + `<Key>`
     10 - on Windows, use `<Shift> + <Alt> + <Key>`. This works for the most common browsers, such as Firefox, Chrome, Safari and Internet Explorer
     12See [wikipedia:Access_key#Access_in_different_browsers access in different browsers] for more details.
    1313
    1414 * `1` - WikiStart
    2323 * `f` - Search
    2424
    25 == TracBrowser Access Keys
     25== TracBrowser Navigation
    2626
    27 * `j` - Select next entry
    28 * `k` - Select previous entry
    29 * `o` - Expand folder/view file
    30 * `<Enter>` - Expand folder/view file
     27The browser can be navigated using the keys listed below. The key modifiers listed above are not used for navigating the browser.
    3128
    32 ----
    33 See also: TracGuide
     29* `j` and `k` - select the next or previous entry, starting with the first
     30* `o` ('''o'''pen) - toggle between expanded and collapsed state of the selected  directory or visit the selected file
     31* `v` ('''v'''iew, '''v'''isit) and `<Enter>` - same as above
     32* `r` - '''r'''eload an already expanded directory
     33* `a` - directly visit a file in '''a'''nnotate (blame) mode
     34* `L` - view the '''L'''og for the selected entry
     35
     36If no row has been selected using `j` or `k`, the keys will operate on the entry under the mouse.
