Changes between Version 4 and Version 5 of How to document the quickstart file
- 3 Nov 2019 14:15:30 (15 months ago)
v4 v5 52 52 53 53 54 First sentence defines what the application does. 55 You may also need to include a sentence of two describing the domain. 56 Eg: For a Business Intelligence application, you should describe what 57 Business Intelligence is. 54 .. Writing Tip: Overview section 55 This section is required and has no heading. Start with a sentence describing what the application is and does. 56 57 This application is a GIS Desktop client for editing and viewing Geospatial data. 58 59 .. Writing Tip: 60 Next, describe what will be covered in the Quick Start. Choose a few features to show. If you're showing one or two things, write that in sentence format. If it's three or more, use a bullet list. Optionally, you can also manage expectations about the length of the Quick Start - how much time should the user expect to commit to this activity? 58 61 59 62 This Quick Start describes how to: 60 63 61 64 * Add a title and subtitle 62 * Add a link 63 * `Web Map Service (WMS) <http://www.opengeospatial.org/standards/wms>`__ 65 * Add a link `Web Map Service (WMS) <http://www.opengeospatial.org/standards/wms>`__ 64 66 * use the standard map tools 65 67 * apply color to map features using styling 66 68 69 70 .. Writing tip: prerequisites section 71 This section is optional. Mention any prerequisites that are required to complete the Quick Start, for example, internet connection or data to test with. 72 73 This guide uses some of the sample data included with OSGeo Live. Make sure you can access /usr/local/share/data. 74 67 75 .. contents:: Contents 76 .. Writing Tip: 77 Use headings in your document to automatically generate a table of contents. The headings should start with verbs, and should be the same or similar to what you have said the Quick Start will cover. 68 78 69 79 This is a title … … 74 84 Here a paragraph is starting because of the blank line above. 75 85 But this line belongs to this second paragraph. 86 87 .. Writing Tip: 88 The heading title for the first section is "Start application name". Use numbered steps to describe what to do. Steps start with a verb or action word. Include only one action per step. A description of the expected result is not a new step. 89 Use Sphinx inline markup such as :guilabel: for buttons and field names; and :menuselection: for selecting menu items. Also refer to this page to describe elements on the UI https://developers.google.com/style/ui-elements 90 91 76 92 77 93 This is a subtitle … … 109 125 .. image:: /images/projects/<slug>/image_name.png 110 126 :scale: 70 % 127 .. .. Writing Tip - Images: 128 For images, use a scale of 50% from a 1024x768 display (preferred) or 70% from a 800x600 display. Markup the graphic with red circles to highlight any particular areas of note on the GUI (if required). Store images here: https://github.com/OSGeo/OSGeoLive-doc/tree/master/images/projects/1024x768/ 129 130 .. note:: 131 Notes are optional. You can use them to provide descriptions and background information without getting in the way of instructions. Notes are rendered in the margin in some printed formats. 111 132 112 133 113 .. note:: 114 Notes are used to provide descriptions and background information without 115 getting in the way of instructions. Notes will likely be rendered in 116 the margin in some printed formats. 117 118 119 .. tip:: Tips are used to provide extra useful information, and will 120 likely be rendered in the margin in some printed formats. 134 .. tip:: Tips are optional. You can use them to provide extra useful information or other ways of performing an action like keyboard shortcuts or drag and drop. Tips are rendered in the margin in some printed formats. 121 135 122 136 … … 144 158 ================================================================================ 145 159 146 This section is highly recommended, and should provide pointers further things to try.160 This section is optional. Suggest one or several activities for people to try out on their own. 147 161 148 162 Present a list of ideas for people to try out: … … 165 179 ================================================================================ 166 180 167 168 This section is highly recommended, please provide links to further tutorials and other documentation. 181 This section is required. Provide links to any further documentation or tutorials. If your project has no further documentation, include a link to your project's website or wiki or include a contact email or mailing list to join. 169 182 170 183
