Changes between Version 5 and Version 6 of pkg-java
- Mar 4, 2011, 9:35:19 AM (13 years ago)
pkg-java
v5 v6 3 3 Java 4 4 5 The java package installs a Java runtime environment 6 + the Java Advanced Imaging libraries .5 The java package installs a Java runtime environment 6 + the Java Advanced Imaging libraries + native libs to make the imageio-ext packages work. 6 6 7 7 In order to be able to exploit the osgeo4w structure, keeping consistent with the original java jre structure, a ''bin'' and ''lib'' folder are needed. Therefore the jre is extracted and splitted into the root folder bin and lib, make that way the ''JAVA_HOME'' to be the root of osgeo4w, i.e. %OSGEO4W_ROOT%: 8 8 * java.exe and native libs are extracted to ''osgeo4w''\bin 9 * other libs are put in ''osgeo4w''\lib 10 11 '''Note that this makes it impossible to make two different versions of java coexist. For now java 6 is loaded. We can discuss about the possibility to put java 5 if there are projects that can't work with 6. Feel free to contact me.''' 9 * other libs are put in ''osgeo4w''\lib folder. 10 * license files for ecw and similar are put in the ''osgeo4w''\lib folder. 12 11 13 12 A script is created to set the ''JAVA_HOME'' environmental variable to be %OSGEO4W_ROOT%.
