Changes between Version 30 and Version 31 of pkg-grass
- Mar 14, 2009, 1:35:46 PM (15 years ago)
pkg-grass
v30 v31 71 71 * compile GRASS in a way that it fits in the OSGeo4W directory hierarchy. Example: [http://trac.osgeo.org/grass/browser/grass/branches/develbranch_6/mswindows/osgeo4w/package.sh] 72 72 * package in a tar.bz2 file 73 * write/update "setup.hint" which describes the package and defines the dependencies on other OSGeo4W packages74 73 * if needed, write/update "etc/postinstall/$paketname.bat" which is executed after extraction of the package during installation to define menu stuff and link on user desktop. 75 74 * Depends on the MSYS package for command line operations, because GRASS 6 uses unix shell scripts (GRASS 7 uses Python) 76 * WinGRASS is built with MSYS/MinGW. The libraries used to link to the VC++ built GDAL & friends is in the mingw-libs package. 77 * There is also a grass-vc package, that contains the VC++ built GRASS libraries. These are used in the Quantum GIS GRASS plugin. 75 * WinGRASS is built with MSYS/MinGW. The libraries used to link to the VC++ built GDAL & friends is in the mingw-libs package (copies of the libraries: ''foo''{{{.lib}}} renamed to {{{lib}}}''foo''{{{.a}}}). 78 76 * Release tree: http://download.osgeo.org/osgeo4w/release/grass/ (the installer selects the package with highest version number) 79 77 * Maintainer is JuergenFischer ('''''seeking new package maintainer''''')
