Changes between Version 82 and Version 83 of WikiStart
02/06/25 02:03:59 (7 weeks ago)
jef
  • WikiStart
    v82 v83
    4141== Older versions from repo snapshots ==
    4242
    43 Each time the repository is updated the previous version of the setup.ini is kept.  Old packages files are usually not removed from the repo (unless it necessary to, to make room for new one).  The snapshots reside at https://download.osgeo.org/osgeo4w/v2/snapshots.  To get an older version find the date of the package you want (eg. qgis-ltr-3.22.9-1.tar.bz2 from 2022-Jul-15 14:49 in http://download.osgeo.org/osgeo4w/v2/x86_64/release/qgis/qgis-ltr/) and then pick a https://download.osgeo.org/osgeo4w/v2/snapshots/ from shortly after that date, eg. https://download.osgeo.org/osgeo4w/v2/snapshots/20220715-190611/. Add that URL as `User URL` on the "Choose a download Site" page and pick only that (or via the command line option `--site` with `--site-only`).  Picking `qgis-ltr` will then get you 3.22.9 instead of the latest version.  I'd recommend to do this in a separate installation as in existing installations versions of dependencies probably won't be properly downgraded and will likely break.
     43Each time the repository is updated the previous version of the setup.ini is kept.  Old packages files are usually not removed from the repo (unless it is necessary to make room for new ones).  The snapshots reside at https://download.osgeo.org/osgeo4w/v2/snapshots.  To get an older version find the date of the package you want (eg. qgis-ltr-3.22.9-1.tar.bz2 from 2022-Jul-15 14:49 in http://download.osgeo.org/osgeo4w/v2/x86_64/release/qgis/qgis-ltr/) and then pick a https://download.osgeo.org/osgeo4w/v2/snapshots/ from shortly after that date, eg. https://download.osgeo.org/osgeo4w/v2/snapshots/20220715-190611/. Add that URL as `User URL` on the "Choose a download Site" page and pick only that (or via the command line option `--site` with `--site-only`).  Picking `qgis-ltr` will then get you 3.22.9 instead of the latest version.  I'd recommend to do this in a separate installation as in existing installations versions of dependencies probably won't be properly downgraded and will likely break.
    4444
    4545== OSGeo4W Packager (Developer) Information ==
