Changes between Version 69 and Version 70 of WikiStart
- 03/21/16 05:30:39 (9 years ago)
TabularUnified WikiStart
v69 v70 25 25 * Step 2 must be run on a computer with internet access as the installer downloads individual packages as needed. You may also need to enable your software firewall to allow the installer to have outbound access. 26 26 * 32bit/64bit don't contain the same set of packages/versions [http://download.osgeo.org/osgeo4w/versions_diff-x86-x86_64.html (compare)] (purple is 32 bit only) 27 * Don't blindly do a full install in Advanced mode. Some components require third party additions that need to be installed manually (see the wiki page of the package). Without the addit ons the components might renderer the installation unuseable.27 * Don't blindly do a full install in Advanced mode. Some components require third party additions that need to be installed manually (see the wiki page of the package). Without the additions the components might renderer the installation unuseable. 28 28 29 29 After installation:
