Changes between Version 63 and Version 64 of WikiStart
- Oct 27, 2013, 9:20:05 AM (11 years ago)
WikiStart
v63 v64 16 16 == Quick Start for OSGeo4W Users == 17 17 18 19 20 1. Download the [http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe OSGeo4W Installer (32bit)] (or new experimental OSGeo4W Installer [http://download.osgeo.org/osgeo4w/testing64/osgeo4w-setup-x86.exe 32bit] [http://download.osgeo.org/osgeo4w/testing64/osgeo4w-setup-x86_64.exe 64bit]) 18 1. Download the [http://download.osgeo.org/osgeo4w/osgeo4w-setup-x86.exe 32bit] or [http://download.osgeo.org/osgeo4w/osgeo4w-setup-x86_64.exe 64bit] OSGeo4W network installer (previous [http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe 32bit only installer]) 21 19 2. Run the installer. 22 20 3. Select ''Express Install'', and ''Next''. … … 26 24 Notes: 27 25 * Step 2 must be run on a computer with internet access as the installer downloads individual packages as needed. You may also need to enable your software firewall to allow the installer to have outbound access. 28 * 32bit/64bit don't contain the same set of packages/versions [http://download.osgeo.org/osgeo4w/ testing64/versions_test-testing64.html (compare)]26 * 32bit/64bit don't contain the same set of packages/versions [http://download.osgeo.org/osgeo4w/versions_diff-x86-x86_64.html (compare)] 29 27 30 28 After installation:
