Changes between Version 2 and Version 3 of TracBrowser
04/22/15 15:35:16 (10 years ago)
  • TabularUnified TracBrowser
    v2 v3
    44The Trac repository browser can be used to browse specific revisions of directories
    5 and files stored in the repository of the configured version control system.
     5and files stored in the repositories associated with the Trac environment.
     7''(since 0.12)'':
     8At the top-level of the repository browser is the '''Repository Index''',
     9listing all the configured repositories.
     10Each repository has a name which is used as a path prefix in a
     11"virtual" file hierarchy encompassing all the available repositories.
     12One of the repositories can be configured with an empty name; this is the default repository.  When such a default repository is present, its top-level files and directories
     13are also listed, in a '''Default Repository''' section placed before the
     14repository index. If the default repository is the only repository associated
     15with the Trac environment the '''Repository Index''' will be omitted ^[#note-multirepos (1)]^.
    616
    717Directory entries are displayed in a list with sortable columns. The list
    8 entries can be sorted by ''name'', ''size'' or ''age'' by clicking on the column
     18entries can be sorted by ''Name'', ''Size'', ''Age'' or ''Author'' by clicking on the column
    919headers. The sort order can be reversed by clicking on a given column
    1020header again.
    1121
    1222The browser can be used to navigate through the directory structure
    13 by clicking on the directory names. Clicking on a file name will show
    14 the contents of the file. Clicking on the revision number of a file or
    15 directory will take you to the TracRevisionLog for that file.
    16 Note that there's also a ''Revision Log'' navigation link that will do
    17 the same for the path currently being examined.
     23by clicking on the directory names.
     24Clicking on a file name will show the contents of the file.
     25Clicking on the revision number of a file or directory will take
     26you to the TracRevisionLog for that file.
     27Note that there's also a ''Revision Log'' navigation link that will do the
     28same for the path currently being examined.
     29Clicking on the ''diff'' icon after revision number will display the changes made
     30to the files modified in that revision.
     31Clicking on the ''Age'' of the file - will take you to that changeset in the timeline.
    1832
    1933It's also possible to browse directories or files as they were in history,
    2236the ''View revision'' input field at the top of the page.
    2337
    24 ''(since 0.11)'':
     38The color bar next to the ''Age'' column gives a visual indication of the age
     39of the last change to a file or directory, following the convention that
     40'''[[span(style=color:#88f,blue)]]''' is oldest and '''[[span(style=color:#f88,red)]]'''
     41is newest, but this can be [TracIni#browser-section configured].
    2542
    26 The color bar next to the Age column gives a visual indication of the age
    27 of the last change to a file or directory. In the default configuration,
    28 blue is older and red is newer, but this can be [TracIni#browser-section configured].
    29
    30 At the top of the browser page, there's a drop-down menu which you can use
     43At the top of the browser page, there's a ''Visit'' drop-down menu which you can use
    3144to select some interesting places in the repository, for example branches or tags.
    3245This is sometimes referred to as the ''browser quickjump'' facility.
    33 The precise meaning and content of this menu depends on your backend.
    34 For Subversion, this list contains by default the top-level trunk directory and sub-directories of the top-level branches and tags directories (`/trunk`, `/branches/*`, and `/tags/*`).  This can be [TracIni#svn-section configured] for more advanced cases.
     46The precise meaning and content of this menu depends on your repository backend.
     47For Subversion, this list contains by default the top-level trunk directory
     48and sub-directories of the top-level branches and tags directories
     49(`/trunk`, `/branches/*`, and `/tags/*`).  This can be [TracIni#svn-section configured]
     50for more advanced cases.
    3551
    36 If you're using a Javascript enabled browser, you'll be able to expand and collapse folders in-place by clicking on the arrow head at the right side of a folder. Alternatively, the [trac:TracKeys keyboard] can also be used for this: use 'j' and 'k' to go to the next or previous entry, and 'o' (or 'Enter') to toggle between expanded and collapsed state of the selected folder or for visiting the selected file.
     52If you're using a Javascript enabled browser, you'll be able to expand and
     53collapse directories in-place by clicking on the arrow head at the right side of a
     54directory. Alternatively, the [trac:TracKeys keyboard] can also be used for this:
     55 - use `j` and `k` to select the next or previous entry, starting with the first
     56 - `o` ('''o'''pen) to toggle between expanded and collapsed state of the selected
     57   directory or for visiting the selected file
     58 - `v` ('''v'''iew, '''v'''isit) and `<Enter>`, same as above
     59 - `r` can be used to force the '''r'''eload of an already expanded directory
     60 - `a` can be used to directly visit a file in '''a'''nnotate (blame) mode
     61 - `l` to view the '''l'''og for the selected entry
     62If no row has been selected using `j` or `k` these keys will operate on the entry under the mouse.
    3763
    38 For the Subversion backend, some additional features are available:
    39  - Displays the `svn:needs-lock` property
    40  - Support for the `svn:externals` property (which can be [TracIni#svn:externals-section configured])
    41  - The `svn:mime-type` property is used to select the syntax highlighter for rendering the file. For example, setting `svn:mime-type` to `text/html` will ensure the file is highlighted as HTML, regardless of the file extension. It also allows selecting the character encoding used in the file content. For example, if the file content is encoded in UTF-8, set `svn:mime-type` to `text/html;charset=utf-8`. The `charset=` specification overrides the default encoding defined in the `default_charset` option of the `[trac]` section of [TracIni#trac-section trac.ini].
     64
     65For the Subversion backend, some advanced additional features are available:
     66 - The `svn:needs-lock` property will be displayed
     67 - Support for the `svn:mergeinfo` property showing the merged and eligible information
     68 - Support for browsing the `svn:externals` property
     69   (which can be [TracIni#svn:externals-section configured])
     70 - The `svn:mime-type` property is used to select the syntax highlighter for rendering
     71   the file. For example, setting `svn:mime-type` to `text/html` will ensure the file is
     72   highlighted as HTML, regardless of the file extension. It also allows selecting the character
     73   encoding used in the file content. For example, if the file content is encoded in UTF-8,
     74   set `svn:mime-type` to `text/html;charset=utf-8`. The `charset=` specification overrides the
     75   default encoding defined in the `default_charset` option of the `[trac]` section
     76   of [TracIni#trac-section trac.ini].
     77{{{#!comment
     78MMM: I found this section a bit hard to understand. I changed the first item as I understood that well.
     79but I think the other items could be changed also
     80 cboos: in the meantime, I've added the ''advanced'' word as a hint this can be a bit complex...
     81}}}
     82
    4283
    4384----
     85{{{#!div style="font-size:85%"
     86[=#note-multirepos (1)] This means that after upgrading a single-repository Trac of version
     870.11 (or below) to a multi-repository Trac (0.12), the repository browser will look and feel
     88the same, that single repository becoming automatically the "default" repository.
     89}}}
     90
    4491See also: TracGuide, TracChangeset, TracFineGrainedPermissions
