Changes between Initial Version and Version 1 of SetupDevelopment
Jul 28, 2008, 9:10:39 PM (16 years ago)
warmerdam
  • SetupDevelopment
     1= Setup Development =
     3The OSGeo4W GUI Installer is derived from the Cygwin GUI Installer described at:
     5  http://cygwin.com/setup.html
     7The modified source can be found in the OSGeo4W SVN at:
     8
     9  https://svn.osgeo.org/osgeo4w/trunk/setup
     10
     11To build, you must first install Cygwin - including quite a variety of development packages.  Then run:
     12
     13{{{
     14./bootstrap.sh
     15./fr_configure
     16make
     17}}}
     18
     19In the setup source directory.  This should produce a setup.exe executable.   The fr_upload.sh and package.sh scripts should also be helpful to get the results to the OSGeo4W download server.  Note that the executable needs to be updated in two places when new versions are uploaded.  One is the http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe binary and the other is the packaged copy in http://download.osgeo.org/osgeo4w/release/setup.
     20
     21== Adding Express Packages ==
     23To add a new express install package follow these steps:
     25# Add a symbolic define for the new package in resource.h in the section at the end (IDC_PKG_OPENEV, etc).
     26# Add a new entry on the express package dialog defined in res.rc (search for IDC_PKG_OPENEV).  Make sure the positioning does not overlap other packages.
     27# Add the new package to the !PackageControlPair[] array in express_package.cc file, matching the IDC_PKG_ constant with the name of the package.
     28
