Changes between Version 39 and Version 40 of PackagingInstructions
- Dec 9, 2015, 2:52:10 PM (9 years ago)
v39 v40 192 192 == Setup.ini == 193 193 194 The Cygwin Setup.exe actually downloads one of the setup.ini files ([http://download.osgeo.org/osgeo4w/x86/setup.ini 32bit] or [http://download.osgeo.org/osgeo4w/x86 /setup.ini 64bit]) with a list of all packages each time it is run. These files should be recreated on the server by running the script invoking `osgeo4w-regen.sh` on the web each time packages are uploaded. This produces a test versions of these files (http://download.osgeo.org/osgeo4w/<arch>/setup_test.ini), which can be used with the setup program (by invoking setup-test.bat in the OSGeo4W shell). Once this has been tested, using the link `osgeo4w-promote.sh` to copy this file to setup.ini, making it live for regular users.194 The Cygwin Setup.exe actually downloads one of the setup.ini files ([http://download.osgeo.org/osgeo4w/x86/setup.ini 32bit] or [http://download.osgeo.org/osgeo4w/x86_64/setup.ini 64bit]) with a list of all packages each time it is run. These files should be recreated on the server by running the script invoking `osgeo4w-regen.sh` on the web each time packages are uploaded. This produces a test versions of these files (http://download.osgeo.org/osgeo4w/<arch>/setup_test.ini), which can be used with the setup program (by invoking setup-test.bat in the OSGeo4W shell). Once this has been tested, using the link `osgeo4w-promote.sh` to copy this file to setup.ini, making it live for regular users. 195 195 196 196 * Generate test versions of setup.ini: `http://upload.osgeo.org/cgi-bin/osgeo4w-regen.sh`
