Changes between Version 36 and Version 37 of PackagingInstructions
- Oct 27, 2013, 12:55:26 PM (10 years ago)
v36 v37 9 9 The installed OSGeo4W directory tree is described in DirectoryLayout. 10 10 11 OSGeo4W packages are generally structured like packages for Cygwin as described at http://cygwin.com/setup.html . 11 OSGeo4W packages are generally structured like packages for Cygwin as described at http://cygwin.com/setup.html . And support two architectures x86 (32bit) and x86_64 (64bit). 12 12 13 13 Packages prepared for OSGeo4W are currently uploaded to: 14 14 15 upload.osgeo.org:/osgeo/download/osgeo4w/release/<package> 16 17 This tree can be reviewed at: http://download.osgeo.org/osgeo4w/release 18 19 Experimental 64bit packages are located on: 20 21 upload.osgeo.org:/osgeo/download/osgeo4w/testing64/release/<package> 22 23 This tree can be reviewed at: http://download.osgeo.org/osgeo4w/testing64/release 15 upload.osgeo.org:/osgeo/download/osgeo4w/release/<arch>/<package> 16 17 This tree can be reviewed at: http://download.osgeo.org/osgeo4w/<arch>/release 24 18 25 19 [[Image(package-name.png, right)]]Each package directory should have a single setup.hint file, and one or more versions of that package as a .tar.bz2 file. These should normally have names like gdal-1.5.0-7.tar.bz2 where "1.5.0" is the version of GDAL that was packaged, and "-1" indicates the version of the packaging attempt. The directory can also contain corresponding source snapshots named like gdal-1.5.0-7-src.tar.bz2. Note that the basename should exactly match the directory in which the package is found. So the "gdal" directory has gdal-<version>-<revision>.tar.bz2 package files.
