Changes between Version 1 and Version 2 of InstallerTranslation
02/15/10 01:22:11 (15 years ago)
jmckenna
minor
  • TabularUnified InstallerTranslation
    v1 v2
    1010   }}}
    1111 * modify line#1 and #2 for your new language
    12    * use appropriate code identifier for your international characters (http://msdn.microsoft.com/en-us/library/dd317756%28VS.85%29.aspx)
     12   * use appropriate code identifier for your international characters ([http://msdn.microsoft.com/en-us/library/dd317756%28VS.85%29.aspx microsoft documentation])
    1313 * replace English installer text in all CONTROL, CAPTION, LTEXT, RTEXT objects, such as:
    1414    {{{
    1919          CONTROL         "インストールせずにダウンロード(&D)",
    2020     }}}
    21      * (background on menu resource accelerators: http://msdn.microsoft.com/en-us/library/syzb5sda%28VS.80%29.aspx)
     21     * (background on menu resource accelerators: [http://msdn.microsoft.com/en-us/library/syzb5sda%28VS.80%29.aspx microsoft documentation])
    2222   * you might have to modify the size/spacing of your new strings in the objects. For example, the values below for "71,120,200,10" mean: x,y,width,height - you might have to change the ''width'' value for longer translated strings
    2323
