Changes between Version 3 and Version 4 of GSoC2013Reports
Jul 29, 2013, 8:50:50 AM (11 years ago)
steve
  • GSoC2013Reports
    v3 v4
    1717
    1818
    19 === Work done in week 17-21 June ===
     19=== Work done in week 17-21 June #1 ===
    2020'''1. Work Done :'''
    2121[[BR]]
    4040  * I will update the wiki of the project to build the new setup.
    4141
    42 === Work done in week 22-28 June ===
     42=== Work done in week 22-28 June #2 ===
    4343'''1. Work Done:'''
    4444[[BR]]
    6262
    6363
    64 === Work done in week 1-5 July ===
     64=== Work done in week 1-5 July #3 ===
    6565'''1. Work Done:'''
    6666[[BR]]
    8181
    8282
    83 === Work done in week 8-12 July ===
     83=== Work done in week 8-12 July #4 ===
    8484'''1. Work Done:'''
    8585[[BR]]
    102102
    103103
    104 === Work done in week 15-20 July ===
     104=== Work done in week 15-20 July #5 ===
    105105'''1. Work Done:'''
    106106[[BR]]
    121121       machine("/OSGeo4W/etc/setup/licenses").
    122122
     123
     124
     125=== Work done in week 29-02 August #6 ===
     126'''1. Work Done:'''
     127[[BR]]
     128     * The main work in this week was around "downloading process" of license file from server. I feel happy because, I finished the first version
     129       of this new extend of Installer. So You can try it:
     130        * Download "setup.override.ini"  file  from "http://trac.osgeo.org/osgeo4w/browser" in the root of your local directory "C:\"
     131        * Download sources from server http://trac.osgeo.org/osgeo4w/wiki/SetupDevelopment and follow the wiki in order to build "setup.exe"
     132        * When you have the setup.exe run it.
     133        * Choose the next option: Advance Install > Install from internet > Root Directory > Local package directory > Direct connection
     134        * Choose a restrictive package for example "gdal-mrsid" or " gdal-ecw " or both,  you should to choose these because I just created a files for each
     135          one in download.osgeo.org server. If you choose another restrictive package setup.exe will raise an error,  and choose another normal package for
     136          example: "gdal-java".
     137        * The setup will download the license file from remote server into your local directory "Local Package Directory" , you can see it If you want.
     138        * The next step setup.exe will load the file into a window and it will show to user
     139        * I committed all my work at [http://trac.osgeo.org/osgeo4w/timeline] from 1230-1233.  This is my work of this week.
     140          * [https://trac.osgeo.org/osgeo4w/changeset/1230]
     141          * [https://trac.osgeo.org/osgeo4w/changeset/1231]
     142          * [https://trac.osgeo.org/osgeo4w/changeset/1232]
     143          * [https://trac.osgeo.org/osgeo4w/changeset/1233]
     144
     145'''2. Problems Faced :'''
     146[[BR]]
     147
     148  *  I had resolved  many problems with segmentation fault. "segmentation fault" when setup.exe does not find a license file in remote server.
     149
     150'''3. Work to be done in the next week:'''
     151[[BR]]
     152    * I will improve some cases when there is no file in remote server and install in "some path" that I will define with my mentor.
     153
     154
     155
