Changes between Version 4 and Version 5 of TracWorkflow
- 09/05/24 07:00:56 (7 months ago)
TabularUnified TracWorkflow
v4 v5 3 3 [[PageOutline(2-5,Contents,pullout)]] 4 4 [[TracGuideToc]] 5 The Trac ticket system provides a configurable workflow. 5 6 The Trac ticket system provides a configurable workflow on how tickets are treated. 6 7 7 8 == The Default Ticket Workflow 8 9 9 When a new environment is created, a default workflow is configured in your trac.ini. This workflow is the basic workflow, as specified in [trac:source:branches/1.4-stable/trac/ticket/workflows/basic-workflow.ini basic-workflow.ini]:10 When a new environment is created, a default workflow is configured in your `trac.ini`. This workflow is the basic workflow, as specified in [trac:source:branches/1.4-stable/trac/ticket/workflows/basic-workflow.ini basic-workflow.ini]: 10 11 11 12 {{{#!Workflow width=700 height=300 … … 62 63 The `accept.permissions` line specifies the permissions the user must have to use this action. [trac:ExtraPermissionsProvider] can define new permissions to be used here. 63 64 64 The `accept.operations` line specifies changes that will be made to the ticket in addition to the status change when the action is taken. In this case, when a user clicks on `accept`, the ticket owner field is updated to the logged in user.Multiple operations may be specified in a comma separated list.65 The `accept.operations` line specifies changes that will be made to the ticket in addition to the status change when the action is taken. In this case, when a user clicks on `accept`, the ticket owner field is updated to the logged in user. Multiple operations may be specified in a comma separated list. 65 66 66 67 The available operations are: … … 158 159 == Example: Adding optional Testing with Workflow 159 160 160 The following adds a `testing` action. When the ticket has status `new`, `accepted` or `needs_work`, you can choose to submit it for testing. When it's in the testing status the user gets the option to reject it and send it back to `needs_work`, or pass the testing and send it along to `closed`. If they accept it, then it is automatically marked as `closed` and the resolution is set to `fixed`. Since all the old workflow remains, a ticket can skip this entire section.161 The following adds a `testing` action. When the ticket has status `new`, `accepted` or `needs_work`, you can choose to submit it for testing. When it's in the testing status the user gets the option to reject it and send it back to `needs_work`, or pass the testing and send it along to `closed`. If they accept it, then it is automatically marked as `closed` and the resolution is set to `fixed`. Since all the old workflow remains, a ticket can skip this entire section. 161 162 162 163 {{{#!ini … … 249 250 == Ideas for next steps 250 251 251 Enhancement ideas for the workflow system should be filed as enhancement tickets against the [trac:query:?status=assigned&status=new&status=reopened&keywords=~workflow&component=ticket+system ticket system] component. 252 Enhancement ideas for the workflow system should be filed as enhancement tickets against the [trac:query:?status=assigned&status=new&status=reopened&keywords=~workflow&component=ticket+system ticket system] component. You can also document ideas on the [trac:TracIdeas/TracWorkflow TracIdeas/TracWorkflow] page.
