Changes between Version 4 and Version 5 of TracModWSGI
09/05/24 07:04:03 (4 months ago)
  • TracModWSGI
    v4 v5
    260260}}}
    261261
    262 Note 1: This is the case where the LDAP search will get around the multiple OUs, conecting to the Global Catalog Server portion of AD. Note the port is 3268, not the normal LDAP 389. The GCS is basically a "flattened" tree which allows searching for a user without knowing to which OU they belong.
     262Note 1: This is the case where the LDAP search will get around the multiple OUs, connecting to the Global Catalog Server portion of AD. Note the port is 3268, not the normal LDAP 389. The GCS is basically a "flattened" tree which allows searching for a user without knowing to which OU they belong.
    263263
    264264Note 2: You can also require the user be a member of a certain LDAP group, instead of just having a valid login:
