Changes between Version 4 and Version 5 of TracUnicode
05/08/22 15:12:10 (3 years ago)
  • TabularUnified TracUnicode
    v4 v5
    33[[TracGuideToc]]
    44
    5 Trac encodes all text using [wikipedia:UTF-8], including text in tickets and wiki pages. Internal processing of text uses true [wikipedia:Unicode] representations. As such, it supports most commonly used character encodings.
     5Trac encodes all text using [wikipedia:UTF-8], including text in tickets and wiki pages. Internal processing of text uses true [wikipedia:Unicode] representations. As such, it supports the most commonly used character encodings.
    66
    7 If the default encoding in your source code repository is not UTF-8, you can specify it in your [TracIni#trac-section trac.ini] file:
     7If the default encoding of your source code repository is not UTF-8, you can specify it in [TracIni#trac-default_charset-option "[trac] default_charset"]:
    88{{{#!ini
    99default_charset = gbk
    1010}}}
    1111
    12 Also ensure that your [trac:DatabaseBackend database] stores its data in UTF-8, otherwise results may be unpredictable.
     12Ensure that your [trac:DatabaseBackend database] stores its data in UTF-8, otherwise results may be unpredictable.
    1313
    14 To convert your database to UTF-8, the easiest way is to create a dump of the database, convert it into UTF-8, for example using [http://www.gnu.org/software/libiconv/documentation/libiconv/iconv.1.html iconv], and then import it back into the database.
     14To convert your database to UTF-8, the easiest way is to create a dump of the database, convert it into UTF-8, for example using [https://www.gnu.org/software/libiconv/documentation/libiconv/iconv.1.html iconv], and then re-import it.
    1515
    1616== Examples
    3737
    3838Ako podržava srpski i slovenski mora podržavati i Hrvatski - čćžšđ ČĆŽŠĐ.
     39
     40=== Dutch
     41
     42Enquêtes in de privésfeer zijn altijd geëngageerd.
    3943
    4044=== English
